Browse Forums Building A New House 1 Mar 12, 2009 4:48 pm Hi member
I have a problem what to do I have got a tender back on my block for a single storey home? Builder told us 1.8m fall over house Need drop edge beams ( we knew this ) Need to but in 10 steps thru the house 5 from gargae to house dan 5 from hallway to living space Need retaining walls ALL FOR THE GRAND TOTAL OF $50k I need to settle on land in 1 week do you think its worth extending ( already have this will be the 2nd time) Do i get a tender from dif builder ? Do you think that all the houses will become split level ? I was advised by this builder to look else where. Re: Tender back WOW now what 3Mar 13, 2009 1:15 am Talk to a builder that specialises in split level designs After 2 false starts, a year living overseas, two more world trips and 3 years of uncertainty we are now starting the build process again - hopefully for real this time! Re: Tender back WOW now what 4Mar 13, 2009 8:09 am Be careful with extending your settlement date. If you delay settlement beyond the completion date on the front of the contract, the vendor is entitled to charge you default interest, usually calculated on about 10% pa on the balance of the purchase price, every day until you settle.
Furthermore, they can serve you a 14 day notice to complete and if you do not settle within 14 days they can terminate the contract due to your breach and sue you for the balance and you will lose the land. Building a Wisdom Homes Impression 33 MkII http://lilypadintheponds.blogspot.com/ We have the keys! Tiling in progress... Re: Tender back WOW now what 5Mar 13, 2009 9:55 pm principessa Be careful with extending your settlement date. If you delay settlement beyond the completion date on the front of the contract, the vendor is entitled to charge you default interest, usually calculated on about 10% pa on the balance of the purchase price, every day until you settle. Furthermore, they can serve you a 14 day notice to complete and if you do not settle within 14 days they can terminate the contract due to your breach and sue you for the balance and you will lose the land. Thanks for the heads up Hey. Head to a metal and decide on which profile you will use first. Profiles with larger corrugations can greatly change the appearance of the color in different… 0 3382 9 24789 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19225 |
