Browse Forums Building A New House 1 Mar 10, 2009 7:09 am Hi all just need a little advise
I got my tender back i have a beautiful high block 1.8 m fall highest point at the back ( that i'm not ready to give up on) What they did to my house was split it put in about 9 stairs ranging from garage to living area and dug me into the ground at the back by about 2 ruller lengths. all this for a grand price or 45K this is not what we throught was going to happen we throught we would be nice and high didn't realise that our house would turn out to be split level The block behind me would in this case fall from front the back (low in back ) would this make the look over my fence? or should i just get a nother tender with diffrent builder do you think this would change . Re: Tender back fall 1.8m what to do? 2Mar 10, 2009 10:14 am Check this thread out .. i think they're having the same problems ...
http://forum.homeone.com.au/viewtopic.php?t=14831 --- I don't have a signature - just this sentence saying that I don't have one - that'll do! Re: Tender back fall 1.8m what to do? 3Mar 10, 2009 10:54 am I have a smiliar fall at the front and my builder will be doing split level design. The idea behind this is that it lowers the site costs, and gets around council cut and fill requirements.
A second quote is a must to make sure that that the quote is correct.. Also worth asking if that 45k is a final number, or if it changes after the contruction starts... Some builders over quote on site costs and give you the remainder. Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4801 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18538 AS4654.2-2012 External Membranes it is "Informative" but if you get water ingress your insurance assessor will go to this straight away and if not achieved, they will deny… 9 1977 |
