Browse Forums Building A New House 1 Mar 09, 2009 5:10 pm Ok, so we didn't ask the question & just assumed that the builder would put a wall mounted switch inside the garage to open the door when the remotes are not at hand.
But guess what.. Every house previous has had this when the garage door is motorised and we just thought that this was part and parcel, obviously not! I know that we can also open it manually but that is just a PITA. Has anyone else on the forum had this issue or did you get this as standard with your remote operated garage door? Cheers, Dee ---------------------------------------------------------------------------- Our BLOG: http://buildingourdreams.blogspot.com/ Building the 'DEE 257.9' Contract signed 08/09/08. Re: Internal switch for garage door? 3Mar 09, 2009 6:09 pm brittany :shock: What brand is your rollerdoor? I need to check mine is going to have one - I use that function soooooooo much! It's the usual B & D panel lift door with two remotes. We are going to ask the question at our pre-handover inspection in the next couple of weeks. I just can't believe that if it wasn't 'the norm' why it wasn't offered as an option. It's certainly something that we use frequently. Cheers, Dee ---------------------------------------------------------------------------- Our BLOG: http://buildingourdreams.blogspot.com/ Building the 'DEE 257.9' Contract signed 08/09/08. Re: Internal switch for garage door? 4Mar 09, 2009 6:20 pm The unit will have an operation on the back of it if its one of the std chain driven units they use, but for a short person would be very hard to reach. Simple solution is just get another remote controll and mount it on the wall.. done done and done. Re: Internal switch for garage door? 5Mar 09, 2009 6:34 pm My current rental one doesn't have one, but if you take the cover off the unit there is a button on the bottom of it.. So I just leave the cover off.
In my new house it states in the contract that there is a wall button, which will be very handy. Re: Internal switch for garage door? 8Mar 09, 2009 7:55 pm At hand over we got two keyring remotes and a square (bigger than a cigarette packet) plastic remote that we have installed on the garage wall. Maybe you'll get something the same?
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Similar to the above pic but a different colour. Happy at Home Re: Internal switch for garage door? 9Mar 09, 2009 7:58 pm we had one in the first home and it was a "always lit" switch which
was great at night time. our rental doesnt have one and I really miss it. I'm checking with our builder also. Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Internal switch for garage door? 11Mar 09, 2009 8:05 pm mikkyG The unit will have an operation on the back of it if its one of the std chain driven units they use, but for a short person would be very hard to reach. Simple solution is just get another remote controll and mount it on the wall.. done done and done. The motor is mounted in the centre of the ceiling and yes, we are both (ahem) vertically challenged Quote: House-To-Be PostPosted: Mon Mar 09, 2009 7:55 pm Post subject: At hand over we got two keyring remotes and a square (bigger than a cigarette packet) plastic remote that we have installed on the garage wall. Maybe you'll get something the same? Oh, I hope so H2B. Fingers crossed. Yes, a third remote is an option- I guess I am just frustrated that we weren't given the choice. Cheers, Dee ---------------------------------------------------------------------------- Our BLOG: http://buildingourdreams.blogspot.com/ Building the 'DEE 257.9' Contract signed 08/09/08. Re: Internal switch for garage door? 12Mar 09, 2009 8:15 pm Dee, I think you'll find that you will get three. One for the garage and two for your keyring or car. There is no way you'd wanting to be using the ceiling mounted unit.
Hysterical, the PD customers that I know have all got the same as me so I'm guessing it's standard. Happy at Home Re: Internal switch for garage door? 14Mar 10, 2009 5:14 pm I had my B&D panel lift door installed recently. Included in the bag with all the installation booklets, remotes etc was what looked like a light switch. I'm assuming that this is to be drilled to a location of my choice and I presume like the remotes, operate on a wireless signal.
I assume it came standard for me, but my partner organised the door through his connections so can't really tell you 100%. I suggest giving B&D a call to see if you can purchase it separately. Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1218 Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I… 0 6830 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6352 |
