Hi,
We are doing the electrical plan. Just wondering if we need to add some powerpoints in the front yard in case when we need to install some footpath lights along the path to the entrance...
Thanks for any opinions
Browse Forums Building A New House 1 Mar 09, 2009 2:55 pm Hi,
We are doing the electrical plan. Just wondering if we need to add some powerpoints in the front yard in case when we need to install some footpath lights along the path to the entrance... Thanks for any opinions Metricon Amira Re: Powerpoints in the front yard 2Mar 09, 2009 3:19 pm You probably wouldn't plug footpath lights into a power point. they would normally be hardwired.
So just get the sparky to make allowance for future lighting in the front yard and he will run a feed and terminate it in a junction box. ready to go when you do finally decide to install lights. Re: Powerpoints in the front yard 4Mar 09, 2009 3:43 pm wake_me You probably wouldn't plug footpath lights into a power point. they would normally be hardwired. So just get the sparky to make allowance for future lighting in the front yard and he will run a feed and terminate it in a junction box. ready to go when you do finally decide to install lights. Thanks so much for your explanation. Actually, I'm not sure what a junction box works for and how it looks like....can you explain to me?....sorry for having such silly questions... Metricon Amira Re: Powerpoints in the front yard 5Mar 09, 2009 5:12 pm A j box is just a box made of plastic, usually about 100mm x 100mm in the weather proof variety, that is used to house a connection of two cables or more.
You should find the below thread answers a few of your questions https://forum.homeone.com.au/viewtopic.php?t=14756 Re: Powerpoints in the front yard 6Mar 09, 2009 5:29 pm In my quote was a junction box for the rear of the house for a "just in case" scenario - and the sparky just looked at me and said the switchboard box is outside - why would I want a junction box when I could just run cables to exactly where I needed? Fi has moved in!! Re: Powerpoints in the front yard 7Mar 09, 2009 9:23 pm brittany In my quote was a junction box for the rear of the house for a "just in case" scenario - and the sparky just looked at me and said the switchboard box is outside - why would I want a junction box when I could just run cables to exactly where I needed? Depends where your switch board is. obviously it doesn't make any sense to run a new circuit to a location right next to the switchboard. But in most cases provision of an external j box is because its much easier to run cables long distances before sheeting etc. The last thing anyone wants after there house is finished is surface run conduit. there should be ss cable so you can pull up bore pump for service 1 3160 can someone with more experience give me their insight? land is pretty much flat its pretty much at the top of a hill. left and right neighbours are flat in line with my… 0 7467 2 4386 |
