Hi everyone, my first post, so hello to all.
Now I'm building in South Morang which falls under the City of Whittlesea municipality. What is the minimum required distance from the fence line can you excavate before you have to issue your neighbour a "protection work response notice"? I only want to cut vertically and 100mm from boundary.
I have to issue one if its right on the boundary which I can understand.
Also when the cut to block is done, should I have to make a retaining wall that holds in my neighbours fill, or should the neighbour be building a wall to hold in there own fill, so it doesn't fall into our block?
Cheers,
Slippery Sausage
