Browse Forums Building A New House 1 Mar 09, 2009 12:25 pm Hey guys,
I want to know if we can hang a TV on our room wall. I am not sure if the plasterboard can hold the wait of a 47 inch TV. Do we need to ask the builder to add more depth to a particular wall to be able to do that? Thanks! Re: can you hang a TV on the wall? 3Mar 09, 2009 12:37 pm I'm not sure which stage of your build you are at, but If it's not too late, get the chippies to add extra noggins to the wall frames that you are likely to mount TV brackets to. This will make things a lot easier when the time comes. Cheers, Dee ---------------------------------------------------------------------------- Our BLOG: http://buildingourdreams.blogspot.com/ Building the 'DEE 257.9' Contract signed 08/09/08. Re: can you hang a TV on the wall? 5Mar 09, 2009 1:19 pm Plaster sheeting alone WILL NOT hold a T.V, no!
You need to do what has already been advised, best of luck! Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: can you hang a TV on the wall? 6Mar 09, 2009 1:27 pm FarRez is it expensive to add extra noggins? we are almost about to sign the tender and give the commencement fee. It really depends on your builder and how 'flexible' they are. Usually, there are plenty of timber 'offcuts' on site that would suffice for extra noggins. If you are allowed, visit the site at frame stage and ask the chippies nicely, they may be happy enough to do this for you. Sometimes, you are able to negotiate these little extra jobs with the various tradies and offer them some 'cash in hand' for their trouble. Cheers, Dee ---------------------------------------------------------------------------- Our BLOG: http://buildingourdreams.blogspot.com/ Building the 'DEE 257.9' Contract signed 08/09/08. Re: can you hang a TV on the wall? 7Mar 09, 2009 2:58 pm Just keep some spare cash for the bracket .
You can get some cheap ones around eg $60 ,but do you really want to risk a broken plasma by skimping on the bracket? I think not Brackets will cost anywhere from 100-200 for standard and if you are wanting it in a special spot or moveable can be up to $400. Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: can you hang a TV on the wall? 8Mar 09, 2009 4:26 pm NO,NO,NO - don't ask the builder to do it unless he'll do it for free !
You just do it yourself, like everyone else here at homeone. Easy. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: can you hang a TV on the wall? 9Mar 09, 2009 5:21 pm Different bracket will support different weight, so make sure you get a bracket that will be able to support the weight of your tv.
Get a stud finder from bunnings. Find a good location with stud, place bracket where the stud is and mark the holes for the screws. It's fairly easy but just make sure it's the correct bracket. Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: can you hang a TV on the wall? 10Mar 09, 2009 5:27 pm I'm getting in on this one..
And where does one buy a bracket from?? And is there a different bracket for every size tv? Or is it a one size fits all thing? Fi has moved in!! Re: can you hang a TV on the wall? 11Mar 09, 2009 5:32 pm Interesting question this!
When the data/phone/tv guys were roughing out our house (prior to plastering) I asked them where should we put our noggins? Their response was that we didn't need noggins to wall mount a tv; they believed that the existing studs would provide all the support necessary. Our SS (who has been very honest and accommodating) agreed with this opinion also. So, do you really need noggins as well as studs or can you get by with the studs only? 'We make a living by what we get, but we make a life by what we give.' - Winston Churchill Re: can you hang a TV on the wall? 12Mar 09, 2009 6:17 pm You don't 'need' extra noggins to wall mount, and you can get by without them, but they certainly make it easier.
You can just use the existing studs, BUT your positioning may not end up exactly where you want it (eg, centered to the room). Cheers, Dee ---------------------------------------------------------------------------- Our BLOG: http://buildingourdreams.blogspot.com/ Building the 'DEE 257.9' Contract signed 08/09/08. Re: can you hang a TV on the wall? 13Mar 09, 2009 6:23 pm mellybuilding Just keep some spare cash for the bracket . You can get some cheap ones around eg $60 ,but do you really want to risk a broken plasma by skimping on the bracket? I think not Brackets will cost anywhere from 100-200 for standard and if you are wanting it in a special spot or moveable can be up to $400. Ahh you crazy queenslanders ... $60 is plenty to spend on a bracket to hold a 60" lcd/plasma. The difference between a $60 bracket and a $200 bracket is generally where it is bought from and the brand... Go have a look around your local shops and see which brands they have. I wonder if we supply them as well http://www.selbyacoustics.com.au and specifically for brackets for lcd's and plasma's: http://www.selbyacoustics.com.au/storefrontprofiles/deluxeSFshop.aspx?sid=1&sfid=74520&c=84145 Re: can you hang a TV on the wall? 14Mar 09, 2009 8:48 pm She&He+3+3 You don't 'need' extra noggins to wall mount, and you can get by without them, but they certainly make it easier. You can just use the existing studs, BUT your positioning may not end up exactly where you want it (eg, centered to the room). Thanks for your response - nicely clarifies things! We aren't planning to wall mount ATM but may rue our lack of assertiveness down the track . 'We make a living by what we get, but we make a life by what we give.' - Winston Churchill DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 2156 2 10987 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20901 |
