Browse Forums Building A New House 1 Mar 04, 2007 2:29 am Hi,
I'm in the process of finding a suitable design to build a 2 story house with the following features: Ground level: 1, Granny flat 2. At least one master bedroom with private bath facilities. I just can't find many designs! this is the olny one I found so far: http://www.homeworld.com.au/houses.php?houseID=78 but it's starting from $350K!! Anyone knows any other builders who builds similar to what I want? thanks, devank. Re: granny flat + big bed room with bath - 2 level 2Mar 05, 2007 9:34 am Are you after a granny flat specifically? I have seen a few double storey designs where there is a "guest with ensuite and retreat" downstairs, and the master with ensuite and other bedrooms upstairs. The problem with that is that it didn't have a separate access to outside - but I don't know if that's an issue for you.
Ray. Second Time 'Round Re: granny flat + big bed room with bath - 2 level 3Mar 05, 2007 10:27 am Yes ray... I need to satisfy two requirements.
1. A granny flat (It is going to be used as dance studio). Separate entry is preferred. 2. Large room with good bath room facility for my parents to live down stairs. 3. Double garage So far I found only one design! - devank Re: granny flat + big bed room with bath - 2 level 4Mar 05, 2007 6:04 pm ![]() Yes ray... I need to satisfy two requirements. 1. A granny flat (It is going to be used as dance studio). Separate entry is preferred. 2. Large room with good bath room facility for my parents to live down stairs. 3. Double garage So far I found only one design! - devank Also you need to check your council, if granny flat allowed. Old Home Restoration / Renovation Hi All, I am planning to convert my theatre room to 4th bed, is it worth or can we do it with the plan I have attached Thanks for taking your time Regards, Harry 0 1776 If I was to do this I would add extra supports in the ceiling cavity that are independent of any ceiling joists or truss bottom chords. The extra load of the bed wouldn't… 1 1304 The enforcement of the new 7 star rating has been deferred until May 2024 in Victoria https://www.energy.vic.gov.au/for-house ... -standards I would assume that means… 13 9340 |
