Browse Forums Building A New House 1 Mar 02, 2009 11:20 am We have an interesting scenario regarding our tiles in our new home....
We selected a floor tile to go in all wet areas, we were then advised the tile was discontinued and were sent 3 other similar tiles to pick from. We picked a new tile and informed the CSR via phone & email as instructed. Now we discover they have laid the original tile we were told was discontinued. The problem is we have chosen carpet, floorboards and other accessories based on the new tile we were told to select. Also, at no point were we told the original tile selected had become available. Obviously there is a communication issue between builder and tile provider - They have refused to rip them down as tiling is complete... Any thoughts?? Thanks. Re: Wrong Tiles laid?? 2Mar 02, 2009 1:07 pm Did you sign a post contract variation? if yes get them to replace. If you had to sign any paper work at all you should have your own copy use this if not i'm unsure of the legal side of things. Re: Wrong Tiles laid?? 3Mar 02, 2009 3:34 pm This is EXACTLY like the problem I had only a few weeks ago!
They signed a requested variation for new tile, and then they laid the discontinued tile. I argued that they had signed the variation, they agreed, but then they said they signed it on the basis of the discontinuation.. But they signed the document, on a basis of who knows what.. They signed it and we signed it - done. I had a long talk with managers and FINALLY got my way. \ The thing is that if they have signed a document, if you dont have this, you should have written evidence that they agreed. Built the Atlantique 37 Mk2 with Carlisle Homes - WE'RE IN!! Building thread: viewtopic.php?f=31&t=14413 ATLANTIQUE 37 MK2 PHOTOS THREAD - updated 22nd August '09 viewtopic.php?f=31&t=22399 Re: Wrong Tiles laid?? 4Mar 02, 2009 6:45 pm You say you emailed the CSR.. Did you get an email response accepting the change... This is as good as a variation... If not, it's your word against them.... Good Luck... Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: Wrong Tiles laid?? 5Mar 03, 2009 9:31 am Yep - we have it all in writing and they are trying to lay the blame on us for not following the correct process. However, we have done exactly as requested by them.
Expecting a call today from construction manager. I had new concrete laid, extended the alfresco and had the sidewalks concreted too. I noticed the concreter didn't put the expansion foam anywhere, there are expansion… 0 8131 2 31355 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18304 |
