Browse Forums Building A New House 1 Mar 02, 2009 9:17 am Am in the process of acquiring a land that is a battle axe (500sqm). it is on the high side of the street with a cemented driveway 4M wide. We would be sharing the driveway with the house in the middle (the land we want to acquire is the third and last.
We talked to a builder and upon inspection they have some concern. 1. Space to store the materials and delivery and unloading it. So they said that it might be a case that they hand carry it up to the property from the roadside. 2. The driveway of the 2nd house is close to the land so deliveries might be blocking the access of the 2nd house. 3. Parking will be along the street. We didn't think about that because we thought that 4Meters is wide enough and a fire truck can fit in it. Then we talked to other builders yesterday at homeworld and one said it can be a builder's nightmare when I just mentioned about it being a battle axe and can easily bump the Site Cost... (I am hoping not exponentially). Clarendon wants us to pay 600 for them to see the place, but non refundable it they say it is not buildable. So now we are in a dilemma if the land can be built with all the requirement and not exceed the budget by a mile! we like the land but if it is too costly to build on, then we need to assess it again. Should we still pursue the land? Any suggested builder? Initially we wanted to go with big builders as we don't want to end up with a builder and later on closes shop in the middle of the project. Re: Building in a Battle Axe Land 2Mar 02, 2009 10:21 am esm Clarendon wants us to pay 600 for them to see the place, but non refundable it they say it is not buildable. .... Should we still pursue the land? Any suggested builder? Initially we wanted to go with big builders as we don't want to end up with a builder and later on closes shop in the middle of the project. The $600 is standard for all builders - I doubt you'd be able to get someone to do contours and soil test for free. What is it about the land that appeals to you? Is it views? If so - and those views are your dream - then I'm sure you'll find a way to make it happen. If it's location - then you may be able to find another block or old house you can KDR. After 4 years - we're in! Re: Building in a Battle Axe Land 3Mar 02, 2009 11:09 am thanks stonecutter for the reply...
we like the location, that is why we are keen about it. Not really a lot of land available... KDR might be an option. on the $600 requested by clarendon, the first builder (we paid $500) sends first a supervisor to look at the land... if based on his assessment that it is not buildable, then he returns the $500... otherwise, he sends the engr and/or surveyor. Re: Building in a Battle Axe Land 5Mar 03, 2009 7:44 am Hello
We are building in a battle axe site and went to C for the exact reasons as you have been thinking of.... it will be a slow slow build thats for sure. Do you need to build retaining walls ? is the driveway sloping down or up ? is the block level it all depends on all these points. Lobo Buildling a Clarendon Crestmead in Sydney DA Approved on 20/03/2008 Slab Poured on 02/09/2008 Frame Completed 15/10/2008 Brickwork Complete 2/02/2009 Roofwork Complete 05/03/2009 I don't think you're getting a response because you are not quite clear on what the issue is. yep, the site is not level, no site is! but are you just building a garage?… 1 2268 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6448 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24877 |
