Browse Forums Building A New House Re: Solar Hot Water System Rebate 2Feb 27, 2009 8:43 am only if you're replacing an existing HWS. new houses don't get rebates After 4 years - we're in! Re: Solar Hot Water System Rebate 3Feb 27, 2009 9:16 am I think it depends on which state you are in. We are in WA. We haven't had handover of our house yet but the solarhart has been installed. We recieved our waranty info etc from solahart not long ago and the rebate form. Apparently we will get around $1200 back. Some builders we spoke to claimed the rebate and took that off the price they gave you. Re: Solar Hot Water System Rebate 5Feb 27, 2009 9:32 am Are you guys talking about the same thing as this one?
https://forum.homeone.com.au/viewtopic.php?t=14385 Re: Solar Hot Water System Rebate 6Feb 27, 2009 10:05 am Our builder provide's an instant gas system by default. I asked him to change this to a heat pump system which he originally quoted us the full price for. I asked him to check on the rebate and he's going to take the rebate we can get in qld for the heat pump and knock this off the price
so there's a few ways you can do it Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Solar Hot Water System Rebate 7Feb 27, 2009 12:09 pm we might be able to get something back through the victorian energy efficiency targets scheme which commenced 1 jan.
i will get back to you on that one as i have a number of contacts involved who are running the scheme. cheers Re: Solar Hot Water System Rebate 8Mar 09, 2009 7:02 am mattydals we might be able to get something back through the victorian energy efficiency targets scheme which commenced 1 jan. i will get back to you on that one as i have a number of contacts involved who are running the scheme. cheers Hi mattydals Were you able to find out any more on this rebate for Victorians? I would be interested to see if there was a way around it so we could claim something back through the Victorian energy efficiency targets scheme. Cheers, Lee Re: Solar Hot Water System Rebate 9Apr 05, 2009 9:30 pm What about South Australia? Do we get a HWR for new homes? Re: 10Apr 05, 2009 10:24 pm stonecutter1309 only if you're replacing an existing HWS. new houses don't get rebates so when i knock down and rebuild and 'replace' the old system can i get a rebate? in adelaide too, would like to know how the rebate works. -Nathan 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14059 instantaneous is three phase and draws heaps of current, the efficiency comes from not storing it so you don’t lose heat to the environment. The problem is it is not… 5 1103 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20233 |
