Hi all,
I upgraded the wall insulation batts into the golden R2.0 batts and the Sales Quotation says that the batts will be only for the external walls.
Is that normal when quoting wall insulation batts ? I thought it'd cover the whole house
Browse Forums Building A New House 1 Feb 26, 2009 8:54 am Hi all,
I upgraded the wall insulation batts into the golden R2.0 batts and the Sales Quotation says that the batts will be only for the external walls. Is that normal when quoting wall insulation batts ? I thought it'd cover the whole house Re: Wall insulation batts for external walls only ? 2Feb 26, 2009 8:58 am My house also has insulation batts to external wall only
For internal wall, i think people normally use sound batts Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: Wall insulation batts for external walls only ? 3Feb 26, 2009 8:59 am You only require batts for external wall. Thus this is normal.
If you require batts to prevent noise from travelling from one room into another then internal walls can be insulated. Examples are Theatre rooms, bathroom and laundrys. Re: Wall insulation batts for external walls only ? 4Feb 26, 2009 9:15 am For energy ratings it only needs to be the outside walls, and depending on the layout of your house you may choose for noise reasons to put it in other walls.
Its very much the standard to only have it on external walls (sans garage) Found the answer. The recommended distance is .... 1 5987 |
