Browse Forums Building A New House Re: What Hot Water System would you use? 11Feb 24, 2009 1:08 pm Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: What Hot Water System would you use? 13Feb 24, 2009 1:50 pm Stevep79 & Principessa Finished building Wisdom Homes Impression 33mkII in The Ponds, Sydney http://lilypadintheponds.blogspot.com Re: What Hot Water System would you use? 17Feb 24, 2009 2:24 pm Stevep79 & Principessa Finished building Wisdom Homes Impression 33mkII in The Ponds, Sydney http://lilypadintheponds.blogspot.com Re: What Hot Water System would you use? 18Feb 25, 2009 12:11 am It's worth checking the noise rating of the particular heat pump that you intend purchasing. You might not want to place the unit near your bedrooms or where the neighbours will object to the noise of the compressor during the night. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 3 11749 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20194 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24130 |
