Browse Forums Building A New House 1 Feb 21, 2009 4:10 pm We are wanting to have our kit home on stumps. I have three questions:
A) Why does it seem (though my research) that melbourne has much cheaper concrete stumps (approx $70 per stump) as to Brisbane (approx $290 per stump) B) Is it possible to stump our own home or is it something that has to be done by a tradesperson, like eletrical wiring? C) Can anyone tell me what this blurb from our potential kit home is saying? Are they saying we don't need concrete stumps & we can do it ourselves; or something else entirley? Whereby most designs place the stumps in the ground, then place all the bearers & joists on the stumps, then erect the building on top, we instead extend the length of the main load bearing posts of the building. We then fit the steel bearers & joists for both the interior of the buliding & verandah at the required height of the posts. This method has proven itself both stronger, cheaper & easier to construct. Finally we supply extra coloumns to the bearers for streth, whereby the joists can be simply fixed to the tops of the bearers & the flooring fixed to the joist tops for maximum support & longevity. Re: HELP! RE: Stumping of kit home 2Feb 22, 2009 3:49 am I don't have any answers for you but maybe you could post ths in the 'owner builders' thread. You may get more knowledgable responses. Hope that helps. Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16275 From what I know about water tanks (I've been working with a client on them for a few years now) is this - The concrete can last a lifetime if they don't crack for some… 2 10629 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110570 |
