Who's responsible for backfilling around a waffle pod?
The builder has told us it is up to us by we are not happy as this was never explained to us or clearly stated on any documents that we received.
I guess its up to some clever negotiation if you want them to pay for it- I'm not sure what we're going to do...
Anthea
- Class MD Engineered concrete waffle pod slab as per Engineer's report of x date $6640.
- Provide additional bulk concrete and sand t achieve correct founding depth including extra cost of cartage to x location $5825.
As far as we're aware, there was no sand used in the slab at all. we assumed the sand was to backfill. How would you guys interpret it?
cheers
Michelle
then from there if you want the ground built up its a landscaping/paving/anything else you want used matter, they arent going to backfill unless there is soil to do this and it works out that way
my brother built with coral and its this way with his property, and the house across the street is a plantation and its going to be the same, they have just cleaned up the block after it nearly being ready for lockup and they just spread out the remaining soil at the front from the cut and spread it out, its still going to stick out a mile
i think its one of those things that you only learn as you build or when you watch someone build quite closely
So we know we'll need some well-compacted fill before our new garage will be usable or before installing paths and landscaping.
As we haven't included any external works (driveways, paths, stormwater) in the contract, I expect this will be our problem.
BTW, our termite guru has advised us to keep all paths etc 75mm below the dampcourse. We know this is wise, but think it will look daggy. I guess we'll have to do it, but maybe paint the 75mm of exposed slab the same colour as our render (which is only on the front and one side anyway so we don't know how it will look on the face brick side and back). Anyone else with this dilemma? At our last place the paths were only a whisker below the dampcourse and we had no problems with this in the short time we lived there (29 years!
Cheers
zeke
Dale.
Zeke - yeah that's correct as well about the 75mm exposed.. you are able to identify for termites.. as they will leave a track entry..
If you do go level with it.. which most people do.. you will be liable if there does become termites..
Also don't forget.. insurance does not include termite
Basically you shouldnt cover your weep wholes.
You can fully cover the slab and still have one brick between dampcourse and slab.
2
The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement…
2/05/2023
1
You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would…
17/06/2023
5
Thanks chippy, Budapest for your responses. We've gone with aggregate > I totally know what you mean about the ants here in Perth, they are a pain.
