Browse Forums Building A New House 1 Feb 14, 2009 8:57 am Hi. I would just like to ask whether a council easement (drainage, sewerage) on your property (e.g. 3m of your backyard) totally prohibited you from putting any construction on it? Such as paving it or putting shed. Thanks. Re: easement over the property 2Feb 14, 2009 9:01 am Depends on what the easement is for and what you want to put over it. In our case we had one easement through the centre of our land that could only be built up to 1m to it - not directly over it. That is a structure - we could put paving over it however if the easement was ever needed to be accessed they would destroy whatever was on top and we would be out of pocket. Needless to say we had that easement extinguished as it was only a proposed line that was never utilised.
We also have a 5m wide easement along one side of our block - something to do with the drain beside us. We have planned the house so that is the "dead" side of it and will use it as a driveway area - but again should the Council need to destroy it we have to grin and bear it. Some things are worth waiting for. Re: easement over the property 3Feb 14, 2009 9:14 am My son has a drainage easement for Yarra Valley Water along side his property. It's about 1/4 acre strip down the side of his property. Initially YVW would uproot trees he planted and would not let him fence it in. That caused problems because people would use it as a shortcut, making litter etc.. He spoke with them and now pays a peppercorn rent to YVW, and it's fenced in just like the rest of his garden. Though he can't build on it.
Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: easement over the property 4Feb 14, 2009 9:45 am If it's a standard suburban easement, you can usually do certain things with the land, but not others. Both our previous property and our current one have sewer easements along the rear boundary.
We put up a small colorbond shed, about 2m x 3m at our old place, complete with concrete slab, with the knowledge that if Melbourne Water needed to access the sewer, the shed could be unbolted from the slab and removed (although the slab would be destroyed, of course). We built a much bigger shed as well, but located it just clear of the easement, as we definitely didn't want that one demolished. Planting of trees and shrubs was never an issue. On our current property, we plan to build a 2m x 5m pergola at the back of the house, which will extend over part of the easement. Under normal circumstances we wouldn't need a permit for an unroofed structure of that size, but because it's over the easement, we'll have to apply for one. It should be just a formality, we don't expect any dramas. Re: easement over the property 5Feb 14, 2009 10:29 am i have a drainage/stormwater easement at the back 4m of my property and i cant build on it, so im just building my shed right next to it and parking my camper trailer in that space to make use of it
im not supposed to plant tree's or put any buildings on mine as it will hamper the water flow in heavy rain every easement is different and until you ask you wont know what you can/cant do Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: easement over the property 7Feb 15, 2009 10:21 am Your title and/or plan of subdivision should tell you what type of easement it is and that will tell you who has control over it. Re: easement over the property 8Feb 15, 2009 2:32 pm We applied to City West Water to build a retaining wall on our easement and it wasn't a problem. We eventually plan to pave there as well. It does say in the documentation though that they can move/destroy any approved structure to access their easement. So saying that do you think it makes any difference if you apply or not? Fi has moved in!! You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16146 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1690 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17155 |
