Browse Forums Building A New House Re: High ceilings - How much did you pay for it? Does it help? 21Feb 13, 2009 7:34 am And is your house externally taller than if you had "short" cielings... I bet it is... Generally is not the right word... Rarely is... Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: High ceilings - How much did you pay for it? Does it help? 22Feb 13, 2009 7:41 am chuth77 And is your house externally taller than if you had "short" cielings... I bet it is... Generally is not the right word... Rarely is... No it's not, actually. Exactly the same height before and after. Yes the entire house would be taller if both the bottom and top floor were raised but with just the bottom floor raised, the actual external house height is exactly the same. I don't know whether the standard design of this particular builder's double storeys are done in such away that they allow extra room between floors just in case you want the ceilings raised or some other reason but honestly, the house is excatly the same height. No need to go all bold on me Stevep79 & Principessa Finished building Wisdom Homes Impression 33mkII in The Ponds, Sydney http://lilypadintheponds.blogspot.com Re: High ceilings - How much did you pay for it? Does it help? 23Feb 13, 2009 7:56 am No probs. Generally, the standard (cheapest) engineering of a double story house would not allow for the additional height, without increaseing the external height. Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: High ceilings - How much did you pay for it? Does it help? 24Feb 13, 2009 7:59 am chuth77 No probs. Generally, the standard (cheapest) engineering of a double story house would not allow for the additional height, without increaseing the external height. I was surprised myself and I actually questioned the plans but have been assured that they allow for the height increase internally. Stevep79 & Principessa Finished building Wisdom Homes Impression 33mkII in The Ponds, Sydney http://lilypadintheponds.blogspot.com Re: High ceilings - How much did you pay for it? Does it help? 25Feb 13, 2009 8:19 am stevep79 I was surprised myself and I actually questioned the plans but have been assured that they allow for the height increase internally. So how exactly did they achieve the same height by raising the ground floor? Structurally something would have had to have been done, reduced the floor joist height but decreased the spacings etc. Re: High ceilings - How much did you pay for it? Does it help? 26Feb 13, 2009 8:43 am Correct. The floor joists(truss type system) will have to be reduced, and then strengthen as necessary... This truss type system is typically around 30cm deep, and a web type design to allow for plumbing and electrical services... Reducing this by 6" means the timber needs to be stiffer, and the design of the web truss much stronger... Hence why most builders will just add additional height to the external walls instead! Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: High ceilings - How much did you pay for it? Does it help? 27Feb 13, 2009 1:10 pm From all the builders that I have talked to (based in Vic), change from 2440cm to 2560cm is around $3-4k, and to 2700cm is around $5-6k. Not sure about 3000c, never thought of that high for the whole house, even though we have a Cathedral ceiling in our lounge.
I like high ceiling, it does make your whole place look more spacious, especially if you're building something smaller than 30 SQ. And high ceiling looks nicer with the ceiling fan on (one way to save energy). Imagine the ceiling fan hanging just above your head with the standard ceiling height! Re: High ceilings - How much did you pay for it? Does it help? 30Feb 13, 2009 4:15 pm Can't find my cost but we increased height to 2700 from builders standard of 2400, I am a great fan of higher ceilings, previously lived in a 50 year old double brick house with 9 foot ceilings, which I beleive are around the modern metric 2700, I think it makes house seem so much more spacious and helps it keep cooler in summer. Re: High ceilings - How much did you pay for it? Does it help? 31Feb 13, 2009 7:54 pm I'd always upgrade to 2700. It makes the house feel much bigger. If you plan to have a traditional style house with a bull nose veranda at the front you'll need 2700 or else the veranda will be too low.
House # 2 was only a small one 170 sqm and that cost me $4250 to go from 2400 - 2700 House # 3 quotes have just come in, 2700 is included within the base price for the lower level and 2400 -> 2700 is $3415 for the top level. I was tempted to go 3000 for the bottom floor but instead i'm looking into some coffered ceilings to the formal rooms, i think that will look better. Re: High ceilings - How much did you pay for it? Does it help? 32Mar 09, 2009 5:36 am hey, we paid $7000 to go to 9 and half foot ceilings. pricey but well worth it Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: High ceilings - How much did you pay for it? Does it help? 34Mar 09, 2009 9:39 am Fetaure entry as standard 2890mm, rest of house is in 2590mm. Built the Atlantique 37 Mk2 with Carlisle Homes - WE'RE IN!! Building thread: viewtopic.php?f=31&t=14413 ATLANTIQUE 37 MK2 PHOTOS THREAD - updated 22nd August '09 viewtopic.php?f=31&t=22399 Re: High ceilings - How much did you pay for it? Does it help? 36Mar 09, 2009 7:36 pm We've been quoted around the $2500 mark to go from 2440mm to 2550mm and around $3500 to go to 2700mm high - this is based on a 27 square home. Re: High ceilings - How much did you pay for it? Does it help? 37Mar 10, 2009 12:11 pm Ours is something like $3400 to increase from 2440 to 2600, for a 30sq house --- I don't have a signature - just this sentence saying that I don't have one - that'll do! Re: High ceilings - How much did you pay for it? Does it help? 38Mar 10, 2009 9:42 pm We found that for steel frames increasing the height was very expensive. We put the money into a pool instead Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39735 I was quoting framing timber sizes from Australian Standard AS1684.4 Table A13 for 2700mm wall heights Tile Roof, single storey. This Australian Standard doesn't refer to… 8 7337 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20420 |
