Browse Forums Building A New House 1 Feb 08, 2009 2:54 pm hi all
has anyone got this facade with pd could you post a photo if so our problem is that they dont go right to the bottom of the flashing witch is on the brickwork thanks Re: pd lining board facade 2Feb 11, 2009 8:16 pm Hello Rock,
Our Sorrento Facade had the same look. There was a gap btwn the flashing/top of brick and lining board. The problem is all the Sorrento displays has the same gap!! Our SS said it didn't matter as the flashing hooks up behind the boards so water won't get in, but it looked all wrong. Anyway, prior to settlement I asked them to gap fill it or I wouldn't settle (we had time on our side) & they filled the gaps. Looks good now. Izzys123 Re: pd lining board facade 3Feb 12, 2009 6:39 pm hi thanks for that
they tryed to put a bit of plasic behind it that will never stay! my ss is busy with fires atm so i will put the hard word on the csc!!!! thanks rock Re: pd lining board facade 4Feb 12, 2009 6:41 pm hi thanks for that
they tryed to put a bit of plasic behind it that will never stay! my ss is busy with fires atm so i will put the hard word on the csc!!!! thanks rock Re: pd lining board facade 5Feb 12, 2009 8:11 pm We have weatherboards on our facade above the brickwork - The bottom was fine, but I wasn't happy but with the gaps around the windows, mainly because they were uneven where each board had been cut.
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I asked that the gaps be filled, and they were, no problem. Looks fine now (I don't have a close up). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: pd lining board facade 6Feb 12, 2009 8:28 pm hey kek
the side ones are ok on ours bottom needs something?? hey what front windows do you have? are they refective?? Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3428 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13665 There are a lot of private inspectors should have stayed working as tradies!! Firstly, you paid for a professional opinion of the works, if he has picked up on an item he… 1 2062 |
