Browse Forums Building A New House 1 Feb 07, 2009 7:52 am We have balconies floors being built now between the parapet walls and the front wall of the building. The decision from our builder is a base of 19mm marine ply on top of bearers as the floor construction. This was a surprise as we expected fibrous cement sheets. My experience is marine ply can delaminate and expand. With tiles on top I'm concerned moisture could be trapped,... the vicious cycle begins
SS explained using fibrous cement sheets is too heavy for construction people and C could not meet the OHS rules for the building. I'm guess waterproofing the ply, then tiles on top of marine play should be long lasting. We aware of other C people with balconies suffering leaks. The suggestion was from C was dark tiles resulted in expansion due to "heatsink" factor. The feedback was use light colour tiles to stop heat collection and expansion. Is anyone else aware of any issues with the marine ply construct? gongbuilding Re: For external balconies floor - marine ply or fibrous cement 2Feb 08, 2009 11:33 am Our attention to the detail of the balcony flooring was largely influenced by the number of balcony collapses mentioned in news items over the last 6 mths. There has been associated serious injuries.
With our balconies the intent was to have them for our own preference for the views but equally for the resale vaIue as the house will look over the coastline. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ However we want a design which could potentially minimise any contribution to fatigued floor structures. We will have lots of salt water etc. The frame for balcony flooring is treated timber. I think the fixing nails are normal steel or gal. Then on top of the structure ( see below) the marine ply will sit. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If there are people with experience with balconies adjacent to the ocean I'd like to hear your opinion especially if you have had to rebuild them ! gongbuilding Re: For external balconies floor - marine ply or fibrous cement 3Feb 09, 2009 3:56 pm I've just confirmed with our SS, that EB will be installing fibrous cement sheeting to our 2 balconies. So does this mean that each SS puts in what he likes & that EB don't have a 'standard' materials list ? Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4456 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3126 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16413 |
