Will project home builders build to just some form of lock up stage, ie without bathrooms, laundry and kitchens installed ?
Thanks
Browse Forums Building A New House Re: Building to Lock Up Stage Only 2Feb 11, 2007 12:54 am I doubt it. I would say that most of the money a builder can earn is from the finishing stages. The biggest problems may come from specifying plumbing and electrics to be completed to a certain level and I guess they'd be very reluctant to handover these services without it being complete/licensed.
Although I know of people who have been successful enough to have things like kitchens taken out of the package. But in their situations they've either formerly worked with the builder or have some affiliation with them. We have had our ensuite tiling and finishing taken out of ours. good luck[/b] Re: Building to Lock Up Stage Only 3Feb 12, 2007 9:11 am We asked a builder to build to lock-up. They replied "we only drop one trade" (this would have been tiling or painting). So the builder missed out, we modified/copied their design and built the house.
But if you don't ask you'll never know. Re: Building to Lock Up Stage Only 4Feb 17, 2007 10:42 am Thanks for your replies.
We will ask the builder prior to signing up. Our problem is we don't trust the quality of installation for bathrooms and kitchens from our past experience with another house. in that instance, they put vanities onto the floor then tiled around them, moisture then got in and expanded the wood and cracked the tiles, Also, the grout lines of tiles did not line up with the floor or wall or bath hob and we thought it looked quite bad. I much prefer to use trusted tradesman for such visible items. Regards Gianna 1 4807 Not unless you have managed to put it as a special condition into the contract somehow. 1 6241 The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8867 |
