Browse Forums Building A New House 1 Jan 27, 2009 6:04 pm Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Rain Water Tank not filling very well 3Jan 27, 2009 7:43 pm Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Rain Water Tank not filling very well 7Jan 28, 2009 10:05 am Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Rain Water Tank not filling very well 9Jan 28, 2009 1:07 pm well thats the problem, ive been watching the water tank entry point for the water to come through when its been raining (not pouring) and there is no water coming out at all, and its not getting to where the inspection point is, its like its diverting to stormwater if there isnt enough pressure or something
the inspection point is located right near the water tank so you cant check the actual underground part..... think ill just have to get onto the builder and find out whats doing Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17361 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31280 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1668 |
