Browse Forums Building A New House 1 Jan 18, 2009 7:18 am Hi, can u guys advice me by looking at the standard specs that I had pasted here on what to add and whether this is enough?
Kitchen Oven: Stainless steel fan forced oven. Hot Plate: Stainless steel 600mm gas cook top. Rangehood: Stainless steel 600mm wide range hood. Dishwasher provision Sink: 1¾ bowl stainless steel sink. Tap: Flickmaster tap, chrome finish. Cabinetry Cupboards: Fully lined melamine modular cabinets. Doors/Drawers: Standard laminate from builder’s selection. Kitchen Bench Top: Post form laminated from builder’s range. Vanity Bench Tops: Laminate square edge. Handles: Selected from builder’s selection. Colours Selected as per Interior Colour Schedules. Bathroom & Ensuite Basins: Vitreous china vanity basin (white). Mirrors: Polished edge mirrors full length of vanity and mounted one tile above bench top. Bath: 1525mm acrylic bath (white) in tiled podium. Shower Bases: 900mmx900mm white acrylic shower bases. Shower Screens: Semi framed shower screens with powder coated aluminium frame (polished silver finish) and clear glazed pivot door. Taps: Chrome tapware. Shower Outlet: Chrome finish in ensuite and bathroom. Toilet Suite: Vitreous china toilet suite in white. Accessories: 600mm towel rails and toilet roll holders in chrome finish securely fitted to timber wall studs. Exhaust Fans: 200mm exhaust fans including self sealing air flow draft stoppers to bathroom and ensuite. Ceramic Tiling Wall tiles to kitchen, bathroom, ensuite and laundry where shown on Plans. Tile selections as per Internal Finishes Schedule Floor tiles to ensuite, bathroom, laundry, WC, kitchen, meals and entry where shown on plans. Selections as per Internal Finishes Schedule 100mm high skirting tiles to bathroom, ensuite, WC and laundry. Carpet Carpet to area’s not tiled. Selections as per Internal Finishes Schedule External Features Brickwork: Clay bricks from builder’s standard range. Mortar Joints: Natural colour Front Elevations: As per Working Drawings. Cement render to selected areas as per plan (Product Specific). Windows: Feature aluminium windows to front elevation (Product Specific). Sliding aluminium windows to sides and rear. Aluminium improved windows throughout. Entry Frame: Aluminium, powder coat finish, clear glazed sidelight(s) (Product Specific). Front Entry Door: Hume range with vertical glass panel (Product Specific). Door Furniture - Front Door: Entrance lockset in polished stainless steel deadbolt. External Hinged Door(s): Entrance lockset in polished stainless steel. Door seal and weather seal to all external hinged doors. Window locks to all opening sashes (keyed alike). Infills Over Windows: Cement sheet infills above side and rear elevation windows and doors. Termite Treatment: Termguard termite spray system where required by relevant authority. Hot Water System Dux 135 gas hot water system with necessary electrical and plumbing connections. Note: Panel and storage tank positioned at the builders discretion. Page 1 of 3 Garage General: Double garage with tiled hip roof including double roller colourbond roller door to front, plaster ceiling and concrete floor. External Walls: Brick veneer (on boundary wall or product specific if required). Pedestrian Door (Product Specific) - Door Frame: Timber, gloss enamel paint finish. Door: Weatherproof flush panel, low sheen acrylic paint finish. Door Furniture: Entrance lockset. Insulation Wool insulation to ceiling of roof space as per 5 star energy rating report (excludes garage ceiling). Wool insulation including sisalation to external brick veneer walls (excluding garage) and wall between garage and house. Note: All insulation will meet required 5 star energy rating requirements Internal Features Room Doors: Flush panel, 2040mm high hinged doors with chrome hinges. Room Door Furniture: Internal lever door furniture in satin chrome finish. Mouldings: 67 x 12mm MDF skirting & 67 x 12mm MDF architraves. Plastic white door stops to hinged doors (where applicable). Door seal and brush strip draft seal to nominated internal doors. Note: This will be in accordance with energy rating assessor’s report. Laundry 45 litre white acrylic with cabinet and bypass. Gallery project chrome tap ware Chrome washing machine stops/grubs. Plaster 10mm plasterboard to ceiling and wall, villaboard to ensuite, bathroom, 75mm cove cornice to living areas, 55mm cove cornice to bedrooms, wet areas, walk in robes and linen cupboards. Roofing Concrete colour on roof tiles from builders standard range. Colours selected as per Exterior Colour Schedules. Colorbond fascia, guttering and downpipes. Paint – 2 Coat Application Gloss enamel to internal doors, jambs & mouldings. Flat acrylic to ceilings. Washable low sheen acrylic to internal walls. Gloss enamel to front entry door. Colours Selected as per Exterior & Interior Colour Schedules. Heating Gas ducted heating to bedrooms and living areas, (excludes ‘wet areas’). Total number of points and unit size product specific. Storage Shelving - Walk In Robe: One white melamine shelf with hanging rail. Robes: One white melamine shelf with hanging rail. Pantry/Linen: Four white melamine shelves. Handles - Internal lever door furniture in satin chrome finish. Framing Stabilized pine wall frame and roof trusses. Page 2 of 3 Boom Plumbing 2 external taps (1 to front water meter and 1 next to laundry exit). Electrical Internal Lights Points: Batten holders throughout house as per standard electrical layout (supply/install light globes to all light fittings in the home). Power Points: Double power points throughout excluding dishwasher and fridge space. TV Point: Two points including 5 metres of coaxial cable to roof space (one to main bedroom and one to living area). Telephone Point: One pre-wired telephone point to kitchen with wall plate as per working drawings including underground draw wire with ability to connect to supply pit. Switch Plates: White wall mounted switches. Smoke Detector(s): Hardwired with battery backup. Safety Switches: RCD safety switch and circuit breakers to meter box. Foundations Up to Class ‘H’ concrete slab, a maximum of 300mm fall with a maximum setback of 5m to the house. Connection Costs Connection of services (water, gas, electricity, sewer, stormwater & telephone conduit). Does not included electricity and telephone consumer account opening fees. Page 3 of 3 Re: standard specs - PLS HELP 2Jan 19, 2009 8:12 am One thing l wish we took more notice of before we built was the laundry exhaust fan, notice they don't mention that! Also electricals, outside points, downlights (not cheap!) extra TV and Telephone and power pts (about $50 each!), also locks whether it be to a bathroom or in our case external garage door etc.
Of course, then that just leaves upgrades that you may want things like air-conditioning, dishwasher, electrical garage door, driveway, stonetop benches, higher ceilings etc! Re: standard specs - PLS HELP 3Jan 19, 2009 8:26 am Just a few things that might matter to you:
- Does your dishwasher provision include plumbing connections and power point? Sometimes they don't.... - Natural mortar is grey. If that works for you, great, but if not, you should be able to upgrade to a different colour for a few hundred dollars. Somepeople care about mortar, some don't. - Acrylic sinks tend to scratch. I prefer stainless steel in the laundry. Again, it's a personal preference. - Depending on how big your house and block are, you might want an extra external tap. As to whether you need to add anything else, it's entirely up to you. The options are limitless: rainwater tank, extra lights, feature lights, extra power points, upgrades to tiles, taps, handles and so on, greywater diversion system, extra kitchen cupboards, paving, air conditioning..... Can you hear the ka-ching! of extra cash flowing out of your pocket? Re: standard specs - PLS HELP 4Jan 19, 2009 8:54 am Things you may want to consider:
- Privacy locks to bathroom/WC - Exhaust fan to laundry/toilet - Hot water system – Is 135 litre is enough? A lot of people in the forum upgrade it to 175 or larger capacity due to family size - Walk In Robe: One white melamine shelf with hanging rail, is this enough? I have added additional rail just to hang more clothes - Pantry/Linen: Four white melamine shelves, is this enough? I upgraded to have a higher pantry door so that I can have 5 shelves instead of 4, it is always good to have extra space in kitchen - Electrical – this has to plan very carefully:- External powerpoint and light point, how many and its position.. Internal powerpoint and light point, and don’t forget that the location of the switches is very important too, I forgot to put the alarm keypad and a light point next to the garage entry door, so when I am home through the garage entry door, I have to go back to the front door and turn on the switch and keypad, although I have not moved into the new house yet but I can foresee the inconvenience that I will be having … Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: standard specs - PLS HELP 5Jan 19, 2009 11:30 am One problem I see is that your specification is not detailed enough. for instance, the kitchen specification is:
Kitchen Oven: Stainless steel fan forced oven. Hot Plate: Stainless steel 600mm gas cook top. Rangehood: Stainless steel 600mm wide range hood. Dishwasher provision Sink: 1¾ bowl stainless steel sink. Tap: Flickmaster tap, chrome finish. If I was a builder and tried to maximise my profit (and didn't care about the customer), I could probably buy all these items from an unbranded manufacturer for about one-third of a name brand. Just like you can go to Woolworths and buy a $99 colour TV that comes from Sonic or some other unheard of name. Try buyiong a $99 Sony TV. Demolition August 2009, Construction Started September 2009, Completed December 2010 standard 6Jan 19, 2009 2:31 pm hey Casa,
I agree definately with extra powerpoints. This is a must. And lock on WC One thing i've noticed is that you have heating, but not cooling. Is this actually both? Because if it's not or you're not sure you should ask. Re: standard specs - PLS HELP 7Jan 20, 2009 7:10 pm hey guys thanks a lot for the inputs!
CASA - can i ask the builder for the brand? claedo - u mean all the doors doesnt come with locks????? yes it doesnt come with any cooling system. just ducted heating. how mmuch is the evaporative cooling? if its expensive i will be happy with just using the fan Re: standard specs - PLS HELP 8Jan 20, 2009 7:23 pm cococrunch hey guys thanks a lot for the inputs! CASA - can i ask the builder for the brand? claedo - u mean all the doors doesnt come with locks????? yes it doesnt come with any cooling system. just ducted heating. how mmuch is the evaporative cooling? if its expensive i will be happy with just using the fan The builder should certainly tell you the brand. This way you can go look at it and see if it's acceptable to you. Can't see why the builder would not tell you exactly what they intend to use. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: standard specs - PLS HELP 9Jan 20, 2009 7:42 pm Hi Cococcrunch,
Think wisely about storage too! What is the configuration with the kitchen cabnets? Can you add pot drawers? Can you build in the laundry trough into a cupbord with a bench for extra storage? Do you like the look of infils above the windows, or can you upgrade to have brick instead (can be expensive). Are eaves standard...if you want/like them? Do you want flush internal doors, or something panelled? What about stone benches in the kitchen? Are the skirtings and arches big enough or can you upgrade these? ...and the list goes on! There are so many different upgrades you could choose if you wanted to. It all depends what you like (it's going to be your home), and what you think is important in the look and practicallity of your home! We ended up spending almost $75K on upgrades including grand alfresco, stone benches to bathrooms, 2 pac kitchen, extra storage in laundry and many, many powerpoints and low voltage downlights. You also need to think what is easier to do NOW, rather than later! Definitely structural changes need to be thought about now (choice of bricks, windows, roof tiles, extra rooms, electrical layout, alfresco etc), but other things can be added in later and possibly cheaper (but more inconvenient!). Have fun choosing all your options and making your home something you can be proud of. That, believe me is the easy part...and we haven't even started yet! Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: standard specs - PLS HELP 10Jan 24, 2009 9:56 am hi guys..i have more details
22. KITCHEN Benchtops: Laminated post formed (from builders range) Cabinets: Laminated (from builders range) O'head Cab's: Laminated Doors: Laminated Tap: Aqua Sinkmixer Sink: Radiant stainless steal 1 3/4 Bowl Dishwasher: Provision Rangehood: Venini Geh6001 Stainless steel Cooktop: Venini Vgc6ss (gas) Stainless Steel Oven: Venini Vff06ss (electric) Stainless Steel is this ok guys??? Re: standard specs - PLS HELP 12Jan 24, 2009 7:42 pm cococrunch claedo - u mean all the doors doesnt come with locks????? Privacy lock for internal doors is not standard for a lot of builders But external doors & windows normally come with locks (but i do know that it is an extra for some builders), so you should check with your builder and confirm what is included and what is not Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2578 Hi there, long-time lurker but first time posting. I've bought a house 2 and a bit years ago and last year we had some major water damage on a converted pergola area… 0 7936 Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12533 |
