Browse Forums Building A New House Re: Which plan to choose? 21Jan 18, 2009 10:31 am 2nd build here we come in Whittlesea! https://forum.homeone.com.au/viewtopic.php?f=31&t=92617 1st Build - Henley - Cooper in Doreen! (2009) https://forum.homeone.com.au/viewtopic.php?f=31&t=17354 Re: Which plan to choose? 26Jan 18, 2009 3:03 pm Another good thing about plan #2 is the garage access setup. I dislike garages opening directly into the entry, so having that small area tucked behind the garage gets it out of sight.
It's also right next to the laundry, which is handy for cleaning up greasy hands or disposing of mucky clothes, without traipsing through the house. Anthony Firstly, wow you have put a lot of work into your list of questions! Great job and they are mostly valid questions that a builder should be able to answer. As… 14 9097 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 4595 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 6107 |
