Browse Forums Building A New House 1 Jan 17, 2009 1:37 pm Sorry Nexus, I stole your photo as it’s a good one to ask my question with, I hope you don’t mind.
Wrapping……do we do this in NSW? I don’t think I’ve seen it where I live. What are the benefits of it? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wrapping in NSW???? 2Jan 17, 2009 1:40 pm i dont think so, not that i go to building sites much. it's obviously for insulating against moisture? Re: Wrapping in NSW???? 3Jan 17, 2009 1:52 pm I thought moisture possibly as well, what happens if you want to insulate the walls as well? You have insulating and wrapping?
Strange…… Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wrapping in NSW???? 4Jan 17, 2009 4:31 pm That's ok Michelle!
Basically yes, it's for insulation There is a webite on sisaltion (.com.au) which explains it all Building our dream H3nl3y home together House: Cott3sloe Modifications: Extended ensuite, grand dining, grand rumpus, Bedroom 4 option, two plus garage Frame done, roof tiles are on, brickes start this week! Re: Wrapping in NSW???? 5Jan 17, 2009 4:35 pm Mich I've never seen it in NSW either, but then again, it's only now I've been looking at houses being built.
Would be interested in what others have to say, and why it's not done in NSW??? Still not in. Don't ask!? Re: Wrapping in NSW???? 6Jan 17, 2009 6:19 pm Nexus That's ok Michelle! Basically yes, it's for insulation There is a webite on sisaltion (.com.au) which explains it all Thanx Neus…. I’ve been to a lot of building sites, and I’v never seen it before. Might ask my neighbour why we don’t do it. Do they do it in Queensland, SA & WA? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wrapping in NSW???? 9Jan 17, 2009 6:50 pm Yes its done in queensland, not sure if its mandatory or not though Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Wrapping in NSW???? 10Jan 17, 2009 7:19 pm See the roll in the left corner, silver and blue?
That’s the one we use here, in the roof and occasionally on the walls. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ But the one being used in all the photos looks like plastic? I know the blue and silver one and I know what it’s used for, but the plastic is what I find strange. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wrapping in NSW???? 12Jan 17, 2009 7:28 pm Yes that's what we call it, but in the website they call it sisalation.
http://www.sisalation.com.au/contact-us Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wrapping in NSW???? 13Jan 17, 2009 7:39 pm Actually on closer inspection that sisalation on that website does look different to ours. Ours is more like a tarp. It also has a rip in it around the side
As for WA - I'm now interested to know why they mostly double brick? Building our dream H3nl3y home together House: Cott3sloe Modifications: Extended ensuite, grand dining, grand rumpus, Bedroom 4 option, two plus garage Frame done, roof tiles are on, brickes start this week! Re: Wrapping in NSW???? 14Jan 17, 2009 7:43 pm Nexus As for WA - I'm now interested to know why they mostly double brick? I think for the heat Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wrapping in NSW???? 15Jan 17, 2009 7:48 pm Nexus Actually on closer inspection that sisalation on that website does look different to ours. Ours is more like a tarp. It also has a rip in it around the side So yours isn’t plastic, it’s a tarp type material? Looks like plastic……do they staple it on with a staple gun? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wrapping in NSW???? 16Jan 17, 2009 8:01 pm Not sure how it's attached, to be honest I shall have a closer look at it when we're on site again on Monday.
Just did a quick search as I've totally confused myself (not hard lol) as to whether it really is sisalation or, as bel suggested, sarking I think, though not 100% sure, they are the same thing. Maybe we have it here because it's generally colder than NSW? Only a guess though, lol! Building our dream H3nl3y home together House: Cott3sloe Modifications: Extended ensuite, grand dining, grand rumpus, Bedroom 4 option, two plus garage Frame done, roof tiles are on, brickes start this week! Re: Wrapping in NSW???? 17Jan 17, 2009 8:11 pm I'm not really sure of the difference between sisalation and sarking, but we have both. The sarking is on the roof and the sisilation is on the external walls. They must be different somehow cause we have 2 different colours/types. On the external walls they have used like a staple gun or something.
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ from the inside.. foil like stuff Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We are in Queensland Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! Re: Wrapping in NSW???? 18Jan 17, 2009 8:14 pm That looks pretty much like we use here in NSW, only I think we have the blue on the roof as well. Maybe your roof one is a higher grade because of the heat up there.
NOW that sort off wrapping/sarking? I’ve seen here. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wrapping in NSW???? 20Jan 17, 2009 9:43 pm FWIW, in SA sarking is commonly (but not always) used under roofs. I think it is a requirement under tiles in some bushfire-prone areas. We have it under our colorbond roof. BTW, it need to be "draped" between the purlins to be effective as insulation - not pulled tight.
But I haven't seen it used to wrap the walls of brick veneer houses in SA. If we'd been given that option, though, I would have seriously considered it. I can see several ways it would be beneficial and I can't see any real downside apart from the cost, which would be fairly modest in the overall scheme of things. Cheers zeke Hi, I am in the process of planning to start a kitchen vinyl wrapping business in Auckland, and I am seeking information regarding the average costs for the installation… 0 1963 In NSW the maximum deposit for building work is 5% until the builder provides HBCF insurance 1 4821 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8452 |
