Because M3tricon said the size of Rumpus and Master Bedroom doesn't match, so if for swapping like that to happen, lots of changes are required ~ In summary, they wouldn't want me to change that plan that much
Browse Forums Building A New House Re: Any suggestion on this Floor Plan? 21Jan 15, 2009 6:41 pm brodyb With the Santorini why not swap the main bed to the back where the rumpus is and then make the existing main the theatre? Because M3tricon said the size of Rumpus and Master Bedroom doesn't match, so if for swapping like that to happen, lots of changes are required ~ In summary, they wouldn't want me to change that plan that much Re: Any suggestion on this Floor Plan? 22Jan 15, 2009 6:43 pm wallacetai brodyb With the Santorini why not swap the main bed to the back where the rumpus is and then make the existing main the theatre? Because M3tricon said the size of Rumpus and Master Bedroom doesn't match, so if for swapping like that to happen, lots of changes are required ~ In summary, they wouldn't want me to change that plan that much I think that's a bad idea anyway.... then you would hurt your resale value. I don't think many people would want a house where two of the three alfresco walls are bedrooms. People get big alfrescos so living areas can access it. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Any suggestion on this Floor Plan? 23Jan 15, 2009 7:14 pm If your single the Double Vanity won't be much of an issue!! i have 3 kids and in the morning I'm putting my makeup on and doing my hair, my husbands brushing his teeth and shavin and my kids are fighting over the other bathroom and at times muscling their way into our ensuite.
I would see then if they would consider putting the extra room into the WIR then or making the shower bigger. It is a great plan though!! Good Luck!! Re: Any suggestion on this Floor Plan? 24Jan 15, 2009 7:26 pm The only thing is I doubt you will be able to build a house close to 30 squares for under 210k including driveway, carpets, tiles, paving, blinds, etc etc..
I think you are looking at more realistically around 250k.. add about 50% (seems to be what most people have paid above their base price on here) to your base price for a fully finished and landscaped house. I think for 210k you would probably be looking at 25squares max. But you could have a nice 3 bedroom with study/4th bedroom with nice large living areas and fit it in nicely to 25 squares. Re: Any suggestion on this Floor Plan? 25Jan 15, 2009 7:36 pm wakeboardandy The only thing is I doubt you will be able to build a house close to 30 squares for under 210k including driveway, carpets, tiles, paving, blinds, etc etc.. I think you are looking at more realistically around 250k.. add about 50% (seems to be what most people have paid above their base price on here) to your base price for a fully finished and landscaped house. I think for 210k you would probably be looking at 25squares max. But you could have a nice 3 bedroom with study/4th bedroom with nice large living areas and fit it in nicely to 25 squares. Is JK King Homes that you are building a volume builder or smaller builder? Do they have similar plans that might fit my pocket? 25sq is big enough for me, I've been sharing rooms for many years and i manage to live in a room with my bed next to the table, and my bar fridge hidden inside the closet anyway Re: Any suggestion on this Floor Plan? 26Jan 15, 2009 7:52 pm I have built the Santorini 29. If you have any queries on it just ask!!
I opened up the ensuite to match with the same as the Grandview, took out a wall in middle back bedroom and shelved the wardrobe and use it as a toy room. I do wish I had put double doors on front sitting room, as I have turned it into a home theatre room. I also took out the hallway into the garage and have one large pantry with access from garage into this. I also extended the alfresco out to match straight across from the last back bedroom. It has been almost a year and a half I've been in now. Time goes quickly. Re: Any suggestion on this Floor Plan? 27Jan 15, 2009 8:01 pm wallacetai Is JK King Homes that you are building a volume builder or smaller builder? Do they have similar plans that might fit my pocket? 25sq is big enough for me, I've been sharing rooms for many years and i manage to live in a room with my bed next to the table, and my bar fridge hidden inside the closet anyway They are a volume builder.. biggest regional builder in victoria. But still allow you to customise alot.. This plan is sort of similar to what you are looking for: http://www.jgkinghomes.com.au/homeDetails.php?hid=81 My house was 23 squares total and finished price for everything except landscaping and curtains/blinds was just under 190k which should give you some sort of idea. No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11568 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8768 Thank for yes basically what to remove and what to add, where to place them 2 7322 |
