Browse Forums Building A New House Re: Eaves as shading device for controlling Sun - Please Help. 21Jan 16, 2009 11:11 am Solar Tube lights...do they let alot of heat through...because ovbiously I wouldn't want that...
The suggestion with the 45 degree window sounds good on the corner..I will consider this, but keeping the right angle eave. Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5854 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7843 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7156 |
