Browse Forums Building A New House 1 Jan 07, 2009 8:49 pm I have almost settled on a house plan with PD (Illoura 33- Prestige Range) and I am considering making the double garage into a triple, and also adding a roller door to the rear in lieu of the normal 820mm door.
Has anyone done this with PD or with any other volume builder for that matter? What should I expect to pay? How much wider will I have to make it? I am assuming it will be approx 3m? I need to get a good idea so I can ensure that I can find a wide enough block. The standard Illoura 33 is 14.65m wide (it says it fits on a 15.85m block- so I assume minimum side setback is 1.2m). Built in now city 2009, now moving to the country to embark on another build. Check out our previous blog http://ourpalazzo.blogspot.com/ Re: adding a third garage..how much? PD or other volume builder 3Jan 07, 2009 8:57 pm Can't give you all the costings, but we had our garage made into aa four car size, but within that had a room built as well, and we also added the rear garage roller door. All I remember is that DH sid it was actually reasonable, onsidering the extra work, changes to roof line, etc. Oh, and we built with PD, too! Solidarity, not solidity.......The Lexicon of Life Re: adding a third garage..how much? PD or other volume builder 4Jan 07, 2009 10:11 pm When I was with M3tricon... 9k for the third garage... but it was actually deeper than the normal garage and wider than a normal single. Haven't got precise measurements with me. They have a standard option for a triple on all their houses. Do PD have it as a standard option?
With this builder it was 12k for a triple..... but I've ended up doing an extension rather than a full triple. Around $400 for a rear roller door from memory. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: adding a third garage..how much? PD or other volume builder 5Jan 07, 2009 10:29 pm We got a 2.4m roller door to the back of our garage in our Illoura. We also increased the size, but did not have enough room to go for three cars wide, so we just made it as wide as we could and put in a window to even up the facade. Re: adding a third garage..how much? PD or other volume builder 6Jan 07, 2009 10:35 pm plantation are looking at close to $17k for a third garage.
would have liked one, but that is half of the pool costs and we have over an acre so space for a big shed if needed Re: adding a third garage..how much? PD or other volume builder 7Jan 08, 2009 7:17 am We are with allworth and have added a third garage for $6500, the rear roller door was about $500 and it cost us $750 for an electric opener. Hope this helps.
Mez Re: adding a third garage..how much? PD or other volume builder 8Jan 08, 2009 7:30 am ozzroo plantation are looking at close to $17k for a third garage. would have liked one, but that is half of the pool costs and we have over an acre so space for a big shed if needed Now that's strange as Henley in Vic only charge around $9k Re: adding a third garage..how much? PD or other volume builder 11Jan 08, 2009 9:40 am Back Pocket We got a 2.4m roller door to the back of our garage in our Illoura. We also increased the size, but did not have enough room to go for three cars wide, so we just made it as wide as we could and put in a window to even up the facade. I might end up just extending, and not go for the 'full third garage'. It is mainly for storage, I don't anticipate having a third car in their, however I know it is pretty easy to fill a normal double garage and they tend to be quite a tight fit. How far did you extend the garage? And how much did it cost? How much was the rear roller door? How do they handle the extension- I mean do they just centre the front roller door, or do you have more space on one side than the other? Built in now city 2009, now moving to the country to embark on another build. Check out our previous blog http://ourpalazzo.blogspot.com/ Re: adding a third garage..how much? PD or other volume builder 13Jan 08, 2009 9:59 am Just for interest we are doing the following:
Extending the garage under eaves for 600mm deep and two linen style cupboards both 2000mm long each. This will give us two large storage areas for camping gear etc. In the section closest to the garage door, im going to put light and powerpoint there to create a mini workshop. Cupboards will be closed off with vinyl faced sliders. Cost to us for this is $2700 to the build and approx $800 for the doors. Re: adding a third garage..how much? PD or other volume builder 14Jan 08, 2009 1:47 pm We've extended our garage for storage as well. We're building with PD Prestige.
We extended our garage by 2.3m so now the internal dimensions are 7810x6000mm. That cost $6628. The colorbond roller door to the rear of the garage cost $647 And then we added on two extra windows in the extended area for light and that cost $968. Hope that helps! Our building journey has begun: https://forum.homeone.com.au/viewtopic.php?f=31&t=23138 Brookvale 45 by Porter Davis ************** Lead me not into temptation.....I can find the way myself. Re: adding a third garage..how much? PD or other volume builder 15Jan 08, 2009 4:10 pm Overwhelmed...that's cheap for the size of your extension!
Jas and Rach...we extended our garage by 1.5m - that cost $4,945. Then they added extra site costs associated with extending the garage - $3,907. Plus $360 to add a timber window to match the facade...Grand total $9,212 just for an extra 1.5m of space! Re: adding a third garage..how much? PD or other volume builder 16Jan 08, 2009 4:59 pm seems like there is some wild variations in what the
builders seem to charge for these extensions. I guess at the end of the day, if you are happy with the cost of what you are adding on then so be it... some type of building standardised pricing would be a dream. Re: adding a third garage..how much? PD or other volume builder 17Jan 08, 2009 7:48 pm We have been quoted on the PD Prestige Hayman 29.
To extend our garage to side of the property (16m frontage) adds 770m to the garage for a cost of $2,230 plus $647 for a colorbond rollerdoor at the rear. Making the garage 6000mm x 6300mm. I will also ask for a quote to extend the garage door by approx the same size. The door people have on their website for sizes upto 7000mm. http://www.bnd.com.au/shop/?fuseaction= ... 1&ct_id=82 Anyone had the door sizes increased and have a cost of that? i did click it, still couldnt make it out rofl. in any case, doesnt look like too extreme a slope, you may be in luck. Just shoot out some emails to volume builders in… 3 18515 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110227 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25049 |
