Browse Forums Building A New House 1 Dec 23, 2008 2:37 pm Hi Guys,
We have moved into a rundown house in Sydney Northern districts and plan to knock down and rebuild. The block is downwards sloping (2 metres) and sideways sloping (1 metres). We like the Monash split level design by Huxley homes. Single storey at the front and 2 storeys at the back. I have searched through this forum and found little feedback with Huxley homes. Has anyone had any experience with them? Otherwise any ideas of other builders in Sydney that do split level designs or would modify a single/double storey to suit. Thanks Re: Split level in Sydney. Thinking Huxley 2Dec 23, 2008 2:43 pm Hi and welcome micks_k!
I had some dealings with Huxley early on in our building journey when we were first looking at designs. I went to an appointment at their Parramatta office, and found the sales rep and architect very helpful. That's all I can help with! Cheers Bel Still not in. Don't ask!? isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17836 Move your linen into laundry and access laundry from your present linen space 1 8252 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6756 |
