Browse Forums Building A New House 1 Dec 11, 2008 8:52 pm We are up to the waffle pod stage, and I noticed that some of the steel grid thingy over the white polystyrene has rust on it. Is this normal, or something I should be concerned about? I've seen a few pics here that look like it's quite common, but I'm still not convinced. Can anyone re-assure me?
Judie Re: Rust on metal grid? 2Dec 11, 2008 9:02 pm Judie,
If you are referring to the steel reinforcing then yes, much of it gets left outside and does gather some surface rust. When the slab is poured the reinforcing is encased in concrete and hence no air can get to it, the steel will not continue to rust. Nothing to be worried about however, as its very common what you have noticed. Nathan You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7030 Very common on rendered homes Smaller suppliers get the lower quality raw materials 6 11861 THanks , l got a licensed building inspector to look at the rust, he said its just surface rust and it would take many years to become a problem because the beams are so… 22 28042 |
