Browse Forums Building A New House 1 Dec 02, 2008 12:43 pm Hi everyone,
Would one rainhead behind the garage enough? Rainhead at the front will affect the position of the light on the left of the garage. Is it okay to removed the rainhead at the front? Please help Thanks! Re: One rainhead enough? please help 2Dec 29, 2008 9:11 pm How big is the garage?
What roof area drains to the downpipe? What do you mean by rainhead? Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 6039 Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5852 As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 592 |
