Browse Forums Building A New House Re: How much to add an internal garage access door? 5Nov 17, 2008 10:14 am Hi Penny 73, We are building the carinya and the internal door from the study to garage cost us an additional $389. Re: How much to add an internal garage access door? 6Nov 17, 2008 5:02 pm If its a Henley then it will most likely be a load bearing wall.
Most likely you will need a carpenter, plasterer and painter (unless you want to paint yourself). A carpenter will be a days work to cut out the doorway and frame it up including cutting in a lintel, installing the door frame and hanging the door. Then put on architraves, skirting's and fitting a handle and dead lock (if required). A plasterer would be only a few hours work and once its dry you can sand it yourself. A rough price im guessing would be Carpenter $300 - $350 Plasterer $100 Materials $100-$200 depending on the door handle/lock you choose. I hope that gives you some indication of what is involved. Re: How much to add an internal garage access door? 7Nov 17, 2008 5:51 pm Thanks for that $500 to $600 is ok and worth it I think
This is the link to the floorplan in any case http://www.vic.henley.com.au/#/House/69/FloorPlans/ Thanks again go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110570 |
