Wouldn't write some of these plans off as being larger than you can afford, pricing per square metre varies a great deal depending on the builder and their inclusion lists.
Browse Forums Building A New House Re: Rear-facing living areas in volume building plans 21Nov 10, 2008 4:49 pm russell A little bigger than we can probably afford but it's great to finally see a plan with ALL living areas across the back! Thanks! Wouldn't write some of these plans off as being larger than you can afford, pricing per square metre varies a great deal depending on the builder and their inclusion lists. Re: Rear-facing living areas in volume building plans 22Nov 11, 2008 2:25 am I forgot about the Carlisle Madison...
Just an FYI regarding Carlisle Homes - they will change plans, as long as it doesn't involve changing any plumbing. After 2 false starts, a year living overseas, two more world trips and 3 years of uncertainty we are now starting the build process again - hopefully for real this time! Re: Rear-facing living areas in volume building plans 23Nov 11, 2008 7:14 am Heh, who would have thought plumbing would be the limiting factor.
Thanks for the tip on Carlisle. The Bradford 22 is closer to what we want in size, still has rear-facing living areas but is smaller. Replace alfresco with 4th bedroom but swap its position with the kitchen and it would be great .... but the missus doesn't agree and can't say why . go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110847 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25260 i did click it, still couldnt make it out rofl. in any case, doesnt look like too extreme a slope, you may be in luck. Just shoot out some emails to volume builders in… 3 18633 |
