Browse Forums Building A New House 1 Nov 10, 2024 7:55 am Hi All We're at the end of our build and they have just installed the Fujitsu Reverse Cycle Aircon. However I believe it is not installed correctly as there should be additional screws in all 4 legs (circled in red). Can someone please confirm this? Also the concrete paving at the back attached to the brick wall is quite bad, how will the builder fix this up? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They will install where you want but need conduit to that point, if not it will get installed somewhere easy. NBN has documents on this. 2 6642 0 14241 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 31325 |
