Browse Forums Building A New House 1 Oct 09, 2024 6:28 pm Hi. I have Granitgard around the home as perimeter barrier protection, from the original house build. Due to a minor renovation, i need to top-up the Granitgard. Does anyone know where i can buy granitgard??, as i believe it may have been discontinued last year. Location: Brisbane DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 28418 It is so easy to do yourself. Even if you are not very handy. You literally only need a few basic things from bunnings. Honestly even with the most basic skills I know… 3 12983 Make sure you use appropriate flexible isolation joint between external concrete and building slab/footings for movements. A 10mm Abelflex is ok. 1 11475 |
