Browse Forums Building A New House 1 Jul 13, 2024 3:00 pm Hi all, I'm currently finalising the design for my new home with my builder, and have come across a design challenge that I could use some advice on. There's an empty corner space between the toilet and the sink in the toilet, and I'm worried that the empty might look a bit out of place. Do you think I should make any changes to the design, or would it be better to fill the space with some sort of furniture? I considered extending the bench to fill the space, but I'm also conscious of my budget. Any advice of the matter would be appreciated! Refer to link: https://imgur.com/a/PVP0olw Thank you in advance for your advice. create a wall cavity/through timber to pass 110 mm sewer pipes. As I understand to pass 110m pipe the frame should be greater than 130-150 mm. 2 12883 I'd be very wary of such a product. Aluminium can be prone to corrosion, powder coating will fail if not done perfectly and warranties mean nothing in most cases. Will the… 1 8234 What is going to go in that corner when the floor is filled in? Take that info to a qualified engineer and ask them re the proper procedure/material. 2 15337 ![]() |
