Browse Forums Building A New House 1 Jun 02, 2024 11:26 pm Currently building first time under construction in Sydney,
Are these windows gaps and uneven brick finishing acceptable đ What do i need to ask my builder to fix this issue. outdoor sealing is yet to be done. kindly advise. thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Are these windows gaps and uneven brick finishing accept 2Jun 03, 2024 7:49 am No itâs not. Specially if it exposes the internal framing. Brick cladding is supposed to protect internal structural framing from weather elements as they normally untreated for weather exposure. You need to ask your builder to rectify by possibly provide weatherboard cladding to exposed section of wall and fill in any gaps to avoid further issues. Re: Are these windows gaps and uneven brick finishing accept 4Jun 03, 2024 10:36 am Eng. B A No itâs not. Specially if it exposes the internal framing. Brick cladding is supposed to protect internal structural framing from weather elements as they normally untreated for weather exposure. You need to ask your builder to rectify by possibly provide weatherboard cladding to exposed section of wall and fill in any gaps to avoid further issues. i will ask. outdoor sealing is yet to be done. Re: Are these windows gaps and uneven brick finishing accept 5Jun 03, 2024 1:32 pm If the brickwork does not match what is shown on plans and elevations it is defective and must be demolished and rebuilt Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Are these windows gaps and uneven brick finishing accept 6Jun 03, 2024 7:48 pm building-expert If the brickwork does not match what is shown on plans and elevations it is defective and must be demolished and rebuilt Mistake is happened now i know i am the sufferer but I want a solution to fix it bec i dont think the buider will do this demolish Re: Are these windows gaps and uneven brick finishing accept 7Jun 04, 2024 4:03 am Only way to fix is to pull apart and redo, even then may end up with mortar bit different colour Have more rights now during build than after handover , read your contract Re: Are these windows gaps and uneven brick finishing accept 8Jun 04, 2024 7:30 am B, You and I know each other well outside of the forum, and I really like you. So I am not meaning any ill will by the following comments. I have been with you on this journey well before you chose a builder and I know you have a really tight budget so your choice of builder was really limited What I have seen following your journey is the same thing that is happening to a number of other forum members who also speak with me regularly who are also having issues and it should serve as warning to other people who are looking to build in Sydney, There are a number of Indian builders in the west and south west of Sydney ( mainly targeting the Indian community) who are promising the most amazing specifications and promising to build homes for $1000- 1500/sqm, literally half of what the cost should be. And then you end up with the poorest quality work. Like yours. You have headers missing over windows, a sewer pipe through one of your living rooms and now this brick issue, which I have no idea how they will fix properly, No doubt they will cover it with a massive angle. You are not alone. I have seen slabs poured without drop edge beams and the soil under the slab now hanging 1,000mm in the air on a boundary and the certifier not issuing an OC because of it. Just to name one example. The lesson is you cannot build a 400sqm home in Sydney for $500,000 these days without taking a huge number of shortcuts. Otherwise this is what you get. Don't settle for angles. The brickwork needs pulling down Architectural Homes & Duplexes -Â specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Are these windows gaps and uneven brick finishing accept 10Jun 20, 2024 5:28 pm Did he say how it is going to be fixed? Because the only way to actually FIX it is to pull the wall down and start again. I'd suggest he's got a way of covering his error up and he's calling that a fix. Re: Are these windows gaps and uneven brick finishing accept 11Jun 20, 2024 10:53 pm Who is this builder? Re: Are these windows gaps and uneven brick finishing accept 13Jul 12, 2024 7:43 am These works are not compliant. Any inspector would pick these as defective. There is a code to gaps in brickwork and no âfixingâ will rectify these. Anyâfixingâ undertaken should only be approved once youâve received an independent inspection by a qualified building surveyor that dosnt know the builder. Re: Are these windows gaps and uneven brick finishing accept 15Jul 23, 2024 12:59 pm The window issue has NOT been fixed, it's been covered over. That is not a legit fix. And I will point out that you got lots of good advice earlier (even if it was painful to read) that you chose to ignore over the builders 'fix'. I suggest you get an independent house inspection before this goes any further. And yes, it will cost you (not knowing the details of your house and which state you are in, but I don't think I'm out of line by pulling $2000 out of the air, based on QLD research). Because you show these photos to the engineers and certifier and they not only will have a meltdown, your house will not be legal. And any 'fix' then down the line will cost you much more in the thousands, than just $2k. If not Demolition. Don't let the builder try to sweet talk you, threaten you, promise you or use his own contacts to do inspections. I have to wonder if these window are the only issues you have. R. Re: Are these windows gaps and uneven brick finishing accept 16Jul 25, 2024 1:38 pm Metricon will tell you using angles like this is "accepted industry practice" This is BS, this is a defect, the wall opening is too big for the window and needs to be re-done. Re: Are these windows gaps and uneven brick finishing acceptable 17Sep 13, 2024 3:39 pm Hi we are having the exact same issue with two of our windows with MJH! Iâve been complaining about it from the moment the bricks were finished! Any update or advice for us moving forward before handover! Re: Are these windows gaps and uneven brick finishing acceptable 18Sep 15, 2024 5:25 pm Get an independent building inspection done now. Once handover is done, if they didn't fix it beforehand its doubtful they ever will. Get someone independent from them, not referred by them. And expect to pay for it, however it will should save you lots in the end, or at least give you peace of mind. 7 16093 I have replaced the old window with a new double glazed window, previously occupying the full frame shown below. There wasnât any gaps with the old window. Does the gap… 0 7657 I hope this help you newhome_24, AS3958.1 is the Ceramic Tile Installation Standard. It specifies the tolerances for the installation of tiles. The tile supplier is… 1 19578 |
