Browse Forums Building A New House 1 Jun 01, 2024 7:34 pm Hi there, just after a bit of advice.... New home build - Pool area tiling was to meet the house though they have come up roughly 1700mm too high compared to plan levels and instead of the tiles meeting the house, there is a gap which has a strip drain below. It's a horrible finish and could be hazardous. Builder is refusing to fix as it can no longer come flush to the house due to weep holes. Any thoughts on this? They say that there is no fix. Fair trading has been contacted. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Pool area defect floor level raised too high 2Jun 01, 2024 8:55 pm That is the wrong design, never have a strip drain up against your house. The concrete should slope away from the wall into a strip drain or inlet drain that is away from the building. This could cause foundation movement and house cracking Re: Pool area defect floor level raised too high 3Jun 02, 2024 11:14 pm groundzero That is the wrong design, never have a strip drain up against your house. The concrete should slope away from the wall into a strip drain or inlet drain that is away from the building. This could cause foundation movement and house cracking Do you know if they would have to provide a pool certificate being a house and land package? Re: Pool area defect floor level raised too high 4Jun 03, 2024 8:01 am Depends on levels at pool top and house slab, the concrete paving adjacent to house needs to be upgraded to slope away from house and towards the pool. Adequate wide strip drain may be installed around the pool so pool water and stormwater can flow to the new drain. If the pool top wall level is higher than the house slab level, then the pool may need to be redone to avoid water ponding at the house. Re: Pool area defect floor level raised too high 5Jun 03, 2024 1:10 pm Eng. B A Depends on levels at pool top and house slab, the concrete paving adjacent to house needs to be upgraded to slope away from house and towards the pool. Adequate wide strip drain may be installed around the pool so pool water and stormwater can flow to the new drain. If the pool top wall level is higher than the house slab level, then the pool may need to be redone to avoid water ponding at the house. Unfortunately it is higher than the house slab, after starting to understand this issue more and more we feel the same. This area needs to be redone or the house will eventually suffer from water damage 💔 We are waiting to hear back from Fair trading 🤞 Re: Pool area defect floor level raised too high 6Jun 03, 2024 1:30 pm Has your pool been installed too high? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Pool area defect floor level raised too high 7Jun 03, 2024 1:32 pm building-expert Has your pool been installed too high? Yes, we believe when they put the slab in the ground for the pool that is where the height issue must have started due to wrong measurements, these images above are how they tried to 'solve' the problem Re: Pool area defect floor level raised too high 8Jun 03, 2024 3:51 pm LouLou86 building-expert Has your pool been installed too high? Yes, we believe when they put the slab in the ground for the pool that is where the height issue must have started due to wrong measurements, these images above are how they tried to 'solve' the problem Are there any levels and cross sections on your drawing? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Pool area defect floor level raised too high 9Jun 03, 2024 4:09 pm Their solution is not acceptable as it currently direct stormwater and pool water toward the house which is non compliance with the BCA. Even if the strip drain is designed to take such amount of water which I doubt, it will require regular maintenance. Section 3.1.2.3 of the BCA states: ‘Surface water must be diverted away from Class 1 buildings as follows: (a) Slab-on-ground — finished ground level adjacent to buildings: the external finished surface surrounding the slab must be drained to move surface water away from the building and graded to give a slope of not less than (see Figure 3.1.2.2); (i) 25 mm over the first 1 m from the building in low rainfall intensity areas for surfaces that are reasonably impermeable (such as concrete or clay paving); or (ii) 50 mm over the first 1 m from the building in any other case. (b) Slab-on-ground — finished slab heights: the height of the slab-on-ground above external finished surfaces must be not less than (see Figure 3.1.2.2); (i) 100 mm above the finished ground level in low rainfall intensity areas or sandy, well-drained areas; or (ii) 50 mm above impermeable (paved or concreted areas) that slope away from the building in accordance with (a); or (iii) 150 mm in any other case. Re: Pool area defect floor level raised too high 10Jun 03, 2024 4:23 pm building-expert LouLou86 building-expert Has your pool been installed too high? Yes, we believe when they put the slab in the ground for the pool that is where the height issue must have started due to wrong measurements, these images above are how they tried to 'solve' the problem Are there any levels and cross sections on your drawing? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ No there are not Re: Pool area defect floor level raised too high 11Jun 03, 2024 4:25 pm Eng. B A Their solution is not acceptable as it currently direct stormwater and pool water toward the house which is non compliance with the BCA. Even if the strip drain is designed to take such amount of water which I doubt, it will require regular maintenance. Section 3.1.2.3 of the BCA states: ‘Surface water must be diverted away from Class 1 buildings as follows: (a) Slab-on-ground — finished ground level adjacent to buildings: the external finished surface surrounding the slab must be drained to move surface water away from the building and graded to give a slope of not less than (see Figure 3.1.2.2); (i) 25 mm over the first 1 m from the building in low rainfall intensity areas for surfaces that are reasonably impermeable (such as concrete or clay paving); or (ii) 50 mm over the first 1 m from the building in any other case. (b) Slab-on-ground — finished slab heights: the height of the slab-on-ground above external finished surfaces must be not less than (see Figure 3.1.2.2); (i) 100 mm above the finished ground level in low rainfall intensity areas or sandy, well-drained areas; or (ii) 50 mm above impermeable (paved or concreted areas) that slope away from the building in accordance with (a); or (iii) 150 mm in any other case. Thank you for your reply 1 395 Thanks! I'm spoke to the builder I'm not sure if this is all true but basically went along the lines of they considered all options and if I was to compact and fill it… 2 8427 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 12540 |
