Browse Forums Building A New House 1 May 30, 2024 6:19 pm Hi Everyone, I need some urgent advice. Originally, my tender plans included a basement with the lowest level at 591.550. To get approvals, I had to lower it to 591.000 (a 550mm reduction). Now, the builders are saying that we need pumps to move the sewage and stormwater up to the manholes/ties. Does this sound correct, or should I be concerned? Additionally, the hydraulic plans provided by the builder indicate that around 35m of pipes are required from the basement to the sewage/stormwater connection. Any insights would be greatly appreciated! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Sewage and Stormwater Pumps 2May 31, 2024 1:18 am Without the plans, it doesn't mean much. We are Expert Consultant's, and we are here to help. Re: Sewage and Stormwater Pumps 3May 31, 2024 5:18 am ![]() Hi Everyone, I need some urgent advice. Originally, my tender plans included a basement with the lowest level at 591.550. To get approvals, I had to lower it to 591.000 (a 550mm reduction). Now, the builders are saying that we need pumps to move the sewage and stormwater up to the manholes/ties. Does this sound correct, or should I be concerned? Additionally, the hydraulic plans provided by the builder indicate that around 35m of pipes are required from the basement to the sewage/stormwater connection. Any insights would be greatly appreciated! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Can you post your Architectural and Hydraulic plans so we can see how the system as a whole works? Without that no one will be able to give you any meaningful comments Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. You need to locate those 2 manholes ( the black circles) and run a string line between them They may be covered in dirt or plants but do some hunting and you will… 1 8701 ![]() Hi All! I have engaged a plumber to re-do the stormwater drainage system on my property which is mid-70s and had blocked/cracked clay pipe drains. The works has… 0 37905 Hi all Long time reader here, first time poster. My Mum bought a house a few years back and the downpipes off the bullnose verandah basically just went about a meter… 0 17291 |
