Browse Forums Building A New House 1 May 19, 2024 9:20 pm Re: Capping used under JH Cladding in Façade 2May 19, 2024 9:42 pm Just paint the flashing the same colour as the render. You definitely need the flashing under the cladding it just doesn't need to be that colour Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Capping used under JH Cladding in Façade 4May 20, 2024 2:59 pm Bimbob James Hardies specifies a minimum clearence to botto of cladding, this seems not to adhere to this requirement It's only 6mm required. The picture isn't particularly clear but I think you can just make out a gap from the bottom of the sheet to the flashing Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Capping used under JH Cladding in Façade 6May 21, 2024 6:16 pm Sara thy thanks. hebel panel wall below the JH cladding. what type of painting needs to be done on the black capping, to stay longer Same paint they paint the axon cladding with. Just a regular external water based paint Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Capping used under JH Cladding in Façade 7May 21, 2024 7:44 pm this black capping part is wrapped on top of my hebel wall which will be painted in lexicon quater white. so for seamless look i want to remove this black color and match with hebel paint color lexicon quater white. bec its metal do i need to ask for metal paint specfic to this capping Re: Capping used under JH Cladding in Façade 8May 21, 2024 8:05 pm Sara thy this black capping part is wrapped on top of my hebel wall which will be painted in lexicon quater white. so for seamless look i want to remove this black color and match with hebel paint color lexicon quater white. bec its metal do i need to ask for metal paint specfic to this capping No. The same paint that they paint the wall with will be fine. The builder probably had every intention to paint it and not leave it black. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 it's definitely not looking nice. My builder will give the first floor cladding. We are not very comfortable with this cladding. What cladding you have used. Our is strip… 2 1842 We have a Victorian style ripple iron fence out the front that has some moulded timber capping. Probably 15+ years old and has cracked and splintered in parts...not really… 0 2916 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 8455 |
