Browse Forums General Discussion 1 Apr 07, 2024 4:18 pm Hi All, My house is almost ready but one thing that is bugging me is this 500mmx500mm metal stormwater grate over a box pit in my driveway. The builder says it's an engineering design for the stormwater tank overflow and future maintenance. All I see is a 90mm PVC pipe sticking out of the sand in a plastic box with a grate on top. It is also about 2m away from the stormwater drain on the road. It doesn't look engineered at all and is more of an unfinished eyesore. Is this what they are supposed to be? I don't see this on any neighbours front driveway or yard, or even with the other houses with the same builder. Have a look at these 2 pics and I'd love to hear your comments. Stormwater overflow?Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Storm water overflow pit, is this right? 2Apr 07, 2024 7:55 pm You’d have to check the stormwater plan, every house should have an overflow, imagine if you the bottom house on the street and the stormwater couldn’t cope, you have all the neighbours water coming up out of your stormwater grates and flooding your house. If everyone has one , each yard floods a bit. Re: Storm water overflow pit, is this right? 3Apr 07, 2024 8:21 pm ![]() You’d have to check the stormwater plan, every house should have an overflow, imagine if you the bottom house on the street and the stormwater couldn’t cope, you have all the neighbours water coming up out of your stormwater grates and flooding your house. If everyone has one , each yard floods a bit. Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished product or is there any other work that's supposed to happen. The builder says it's finished.? Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 8894 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 7556 ![]() |
