Browse Forums Building A New House 1 Nov 02, 2008 8:30 pm hi there
has anyone had experience with preparing their own site prior to building? the builder that we are thinking of going with said this should be fine? although havent taking it further yet.. through our work we have access to excavators and family member can do retaining walls etc. We have about 2.5 metre fall accross block. any advise would be great! I just want a bl@@dy home! Re: preparing your own site before building 2Nov 02, 2008 8:53 pm You need to follow the drawings showing required levels exactly, any variation to the levels and site prepareation will allow the builder to claim huge extra costs, so be carefull. Ensure all is done properly and inspected by the building surveyor. It will be cheaper doing yourself usually by huge margin but I've had 3 clients do major site works themselves and got it all wrong, which the builders then claimed additional costs to adjust the house design to suit the incorrect levels, delays etc
With a 2.5m fall just make sure you are well aware what needs to be done and don't let the excavators make the decisions for you. You must instruct them exactly etc etc. Re: preparing your own site before building 3Nov 02, 2008 9:02 pm thanks for advise- can the builder do the cut and fill and we do retaining walls?or is it a process that needs to be done together?
Does any one recommend who we would use to assist? if the contacts through our work dont come through? I have read stories of people using someone other than their builder to level site for building- who would do this? I have no idea (at this very early stage of course) even what section to look under in the yellow pages? he he So many people seem to get ripped off re; site costs. As our block as fall etc- we are a target to be ripped off ! I just want a bl@@dy home! Re: preparing your own site before building 4Nov 02, 2008 9:16 pm There is alot to be done. Too much to talk about here, but breifly you will need a number of trades all at same time, they include setout surveyor to setout the house and site levels for the excavator, you need the many trucks for the excavator to be ready, you need the aggy drains to be laid for the retaing walls, you need all the structural engineering done for the walls and permit issued with building surveyor to inspect the footings for the walls, Will need temp fence and all HSC compliance, The building permit will be part in your name as owner builder or as nominated subcontractors.
Gets messy and with such a decent fall the best person to speak to is to engage building consultant to coordinate all the trades to happen quickly onsite. Re: preparing your own site before building 5Nov 02, 2008 9:23 pm building engineer to overlook work sounds good, at least to get it right. we dont need temporary fencing at our etstate that i do know of- its rural classification. I just want a bl@@dy home! I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3044 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20413 Building a fence now will help limit people dumping rubbish and soil on your property. Many houses in suburbia on small lots have fences up before a build. I moved into a… 1 4396 |
