Browse Forums Building A New House Re: render cost 11Nov 05, 2008 5:18 pm Mrs B Bam Excuse my ignorance, but there are alot of newish houses that i see where the render has something like water stains, marks and cracks on areas close to the roof... Is this due to it being a particular type of render (bagging/moroka????) or workmanship? Hi Bam..I have noticed this to, particularly with the cheaply built, nasty townhouse developments in my area that are sold for a ridiculous amount of money Straight away you can see water stains, cracks and other nasties appearing in these fast 'knock them up' units. Some you can even see the render coming off the walls. I put it down to cheap materials and quick job by the renderer that probably is only being paid a bare minium to do the job. Other reasons...house is built on moving ground therefore cracks are inevitable. Mrs B Thanks Mrs B I wasnt sure whether is was prone to a particular type of render or not. Funny enough, I see it mostly in townhouses too! Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 18072 I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 7964 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 6913 |
