render cost
I am planning to build a 45sq house and I am not sure how much it costs for render of entire house. Does anyone have any idea?
Is it better to have a render or leave it as brick?
Thank you.
We also have a 45sq home which is fully rendered. Through our builder it cost $40,000. Recently the actual renderer came back to complete some touch ups and told me he charged the builder $25,000 so the rest is the builders mark-up. We went through one of the big volume builders.
l think it is personal preference whether you prefer to have the house rendered or leave it brick - depends on the look you are going for.
Good luck!
I heard someone talking of, "acrylic render" that costs a bit more but requires no maintenance, might be worth looking into?
Excuse my ignorance, but there are alot of newish houses that i see where the render has something like water stains, marks and cracks on areas close to the roof... Is this due to it being a particular type of render (bagging/moroka????) or workmanship?
Hi Bam..I have noticed this to, particularly with the cheaply built, nasty townhouse developments in my area that are sold for a ridiculous amount of money
I put it down to cheap materials and quick job by the renderer that probably is only being paid a bare minium to do the job. Other reasons...house is built on moving ground therefore cracks are inevitable.
Mrs B
May also be the Moroka product which is also acrylic.
Mrs B
Thanks Mrs B
I wasnt sure whether is was prone to a particular type of render or not. Funny enough, I see it mostly in townhouses too!
12
Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I…
23/08/2023
I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps…
4/10/2023
5
Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,…
