Soil Testing Cost
We are looking of buying a block of land and then start the discussion with building process. Although we have shortlisted few houses from couple of builders but instead of going for a house & land package, we want to secure the block of land first to allow us to contemplate the house and builder later.
In order to get some idea of site cost prior to deciding about the land, I would like to soil testing done.
Can you guys help me with how much such a soil test cost me?
The land is in Pakenham, Melbourne.
Thanks in advance.
Regards
Sam
Did you want a contour survey done as well? From memory, a soil test and full contours was about $1500
But most builders won't accept it for use - they'll want to do their own soil test & contour survey for around $600 per builder
I have been reading these posts for almost last couple of weeks but still I must say, sorry to sound naive as I am not sure what type of soil testing will I need.
I have been told that the site has some fill and I wanted to get an idea of how much and also the block looks flat but can't depend on what I see with my naked eyes.
Hence I am interested in getting some advice on what will be the site cost if I go ahead with that block of land and thought the soil tests should be some guide related to the same.
I am looking for suggestions and some estimation of how much such a soil test would cost.
Regards
They'll be able to tell you how much fill - some forum members have fill on their blocks and it's increased the site costs substantially.
You should speak to the agent or whoever about this and then arrange for the test yourself.
You should find the cost to be around the $350.00 mark.
at this stage you will only require a straight forward soil test and report - no survey etc
Don't go through a builder - organise it yourself.
Thanks for all the responses. I have talked to the builder and asked them to get me some estimates on a package price for that block. That will be an indicator of the site cost involved and will help me in making the decision.
They have told me that there is substantial fill on that block and hence site cost will be high but I am still waiting for some quantitative figures to compare against.
Do developers of new estate also allow the clause of subject to acceptable soil test? What is the criteria for that condition to pass - site cost within a limit or specific type of slab? I mean, normally, do they want us to specify what we consider as acceptable?
Regards
Good luck
8
We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before…
12/07/2023
1
I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing…
24/07/2023
3
Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report
