Browse Forums Building A New House 1 Mar 28, 2023 10:27 pm Re: Lots of pipes around house boundary 2Mar 29, 2023 1:25 pm that's where your drains should be. the plumber is usually supposed to chop them down to ground level at the end, and cap it with some sort of a grill, like the one you see on the last photo My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6990 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7119 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4704 |
