Browse Forums Building A New House 1 Jan 07, 2023 6:25 pm We've been in our new home for 4 months. Received our first rates notice and rang the council to query the cost, they said a standard house uses around 500 litres a day ours was on par for 1000 litres. We checked the water meter box and this is what we found! It's full of water, we have waited two days to see if this would go down and it hasn't. We took a picture with our neighbours to compare. Would this be covered under the 12-month maintenance? we have the number of the plumber and will ring first thing Monday but just not sure where we stand with our new build. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Water Meter Issue 2Jan 07, 2023 9:59 pm Looking at that and the amount of water you seem to be using it looks like you might have a leak upstream, but relativly close to, the water meter. This pipe would have been installedby the builder. Under the ‘Standard Domestic Building Contracts’ the builder is required to build a house that is ‘suitable for purpose’. That is it complies with the building codes and regulations and will not suffer structural damage or have any other major defect. If you suffer a problem you can go back to the builder under the contract. In effect you have an Implied Guarantee. If the defect was as a result of his construction or the materials they supplied, the builder is liable to remedy as long as the time since the contract was completed is ‘Reasonable’.(https://anewhouse.com.au/2014/07/new-ho ... arranties/) this might be a better way of dealing with the problem than the 'Builders Warranty' which normally has a period of 2 or 3 months! The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Water Meter Issue 3Jan 18, 2023 6:35 am Should be something they come out ASAP to rectify, looking at the neighbors it would appear yours has a leak as I would expect theirs also to be filled if it was seeping in after a rainy day. Defiantly would be going to builder. the conduit would need to be undamaged regardless of what network is in play. The conduit needs to be able to have fibre run through it. NBN and Opticomm are just… 4 3343 Hi all, We're curring working on our outdoor and have some questions in relation to screed. I've tried to find information online, without success. Apologies for the… 0 3724 |
