Browse Forums Building A New House 1 Dec 01, 2022 11:58 am Thought I'd share some pictures of our build. Current status is the frame is going up (Latter pics!). Its got a semi granny flat (not a real one - just an attached area for our in-laws to live with its own living area/bedroom/ensuite). Couple of offices for my wife and I to work from home, in-wall dog door for our lazy dog. The goal is for it to be Passive House certified, so we've got a high focus on insulation/air tightness. Cladding will be Hebel, Hebel flooring on the first floor. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Pretty happy with the progress so far, but plenty of room still for things to go wrong! Re: New house build - Passive House 2Dec 03, 2022 10:14 am Quote: The goal is for it to be Passive House certified Which state is this build in? What are the requirements for the 'passive house' certification? Can any house-build be "converted" to a passive-house, for certification purpose, or does it need planning before the design phase? I'm interested to know more about this ![]() Thanks. Re: New house build - Passive House 3Dec 03, 2022 1:34 pm This is in Sydney. New and existing builds can be certified as passive houses, and I believe there's also a more lenient standard that can apply to renovations. The main aspects of building this way are - high level of air tightness. Needs to be less then 0.6 air changes per hour (tested) - high performance windows and doors (double or triple glazing, thermally broken frames) - heat recovery ventilation - minimal thermal bridges (ie. Continuous insulation) You can do all these things (or a subset) without certification, btw. Re: New house build - Passive House 4Dec 03, 2022 2:51 pm ![]() This is in Sydney. New and existing builds can be certified as passive houses Thanks ![]() ![]() The main aspects of building this way are - high level of air tightness. Needs to be less then 0.6 air changes per hour (tested) - high performance windows and doors (double or triple glazing, thermally broken frames) - heat recovery ventilation - minimal thermal bridges (ie. Continuous insulation) Since reading your post, I started watching some "Sustainable House Day" videos, and learnt more about the different materials, designs and implementations, so, I'm keen to incorporate this approach. I say "incorporate" because, 'passive house' designs look simplistic (which is fine by me!) but there are others that will participate in the decision-making process, who look at cosmetics and are used to seeing cookie-cutter designs, so I'm trying to figure out something that brings in nature into the house, whilst respecting the energy / heating needs at minimal costs. ![]() - heat recovery ventilation This definitely needs constant energy, right? I worry about power outages or having a power outage in winter, when the HRV won't work but opening windows is also problematic (?) I've always lived without any kind of heating or air-conditioning system, so thinking about ducts , HRVs , filters (and maintaining them) , etc... is very new to me. without any air-conditioning or heating, and didn't need to worry about Re: New house build - Passive House 6Dec 03, 2022 3:35 pm ![]() It does require energy and runs all the time, but quite low - around 100w. That is low...even lower than those old desktop tower PCs. What about the running costs, eg. cost of filters? how often are they changed? servicing the HRV ? Does sound travel through the HRV vents, eg. can people hear speech or TV sound through these vents? Re: New house build - Passive House 7Dec 03, 2022 9:31 pm IMHO passivhaus is overrated for Sydney specifically and for Australia in general. 0.6 is a way too tight. HRV will certainly cost more than aircon and what happens if it breaks? I would rather invest in good windows and good insulation, proper thermal mass distribution and passive solar orientation. Keep possibility of natural ventilation and consider using aircon only when needed during heatwaves (e.g. half an hour a day to cool down the house before going to bed and use windows to ventilate during cooler summer nights). Invest into solar batteries and battery (if needed), energy consumption shouldn't be the problem. You probably will be spending $100 more per quarter than with passivhaus, so your investment will never pay up. Re: New house build - Passive House 10Jun 21, 2023 4:53 am Hey Ren Great to see the progress! Looking great Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: New house build - Passive House 11Jun 21, 2023 11:30 am I wish I had of spent some money on trying to get better insulation for the house, never really crossed my mind to be honest. But makes alot of sense as it was the best time to do it during the build. Re: New house build - Passive House 15Jun 22, 2023 10:00 pm Would definitely go passive house if we had the budget. Such well built houses and comfy temperatures! Have seen a couple this year. Re: New house build - Passive House 16Jun 22, 2023 10:10 pm Also, what is the plan with regards to the walls insulation? These studs seem to be standard 90 mm ones so certainly won't be able to fit a lot of insulation. Hebel surely adds a little to the external R values over brick, but I don't really see how you are planning to fight thermal bridging of the framing. Re: New house build - Passive House 17Jun 22, 2023 11:36 pm ![]() Also, what is the plan with regards to the walls insulation? These studs seem to be standard 90 mm ones so certainly won't be able to fit a lot of insulation. Hebel surely adds a little to the external R values over brick, but I don't really see how you are planning to fight thermal bridging of the framing. It is possible to satisfy Passive House requirements in Sydney with standard 90mm studs and R2.5 insulation. I had a design modelled for Passive House with this wall assembly and it passed. As Sydney has a mild climate, especially on the coast, Passive House is relatively easy to achieve compared to other locations and does not have to be overkill. Similarly, 90mm timber studs can pass the thermal bridging requirements for Passive House, at least in Sydney and other locations with mild climates. If there is any doubt, it needs to be modelled. Attention must be paid to frame corners to ensure there is enough insulation and they are not simply packed out with more timber or have voids. Bricks and Hebel blocks/panels typically do not contribute to the wall insulation value for Passive House modelling. External cladding is considered to be outside the thermal envelope of the building if there is a ventilated cavity between the wall and the cladding. Re: New house build - Passive House 18Jun 22, 2023 11:50 pm Oh, thanks, good to know. I have also noticed you do not have any slab edges insulation. Is it also fitting the model? It looks like the main thing for you will be with achieving the right degree of airtightness? But, at the same time, if you are planning to use standard breathable insulation and gyprock, then you should be taking into account additional air exchanges due to higher degree of vapour permeability? But then this OSB you have outside your frame is much less permeable than your insulation and, therefore, will be very well preventing the water vapour from escaping. During colder winter nights and sometime days it will accumulate and condensate and therefore your receive the moisture inside your insulation and framing. Therefore, you should be heavily relying on mechanical humidity regulation (HRV won't be good enough, you would likely require full scale ERV system) as otherwise the mould and rotting will be almost guaranteed in the long run. Unless you plan to install a vapour barrier, but in this case it can be easily punctured during the plasterboard installation. They have this problem in the UK where a lot of houses are using OSB boards in front of insulation and get serious structural damage to their framing in just 15-20 years (due to rotting) and in some cases severe health issues for the residents (due to mould). Re: New house build - Passive House 19Jun 23, 2023 8:09 am Ventilated wall cavity? I'm assuming the house would have gone through wufi modelling. 0 5525 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 21920 Yes, I was happy with the work, bar a few small things. Overall, communication could have been better though. However, I found them reliable and did good work at a… 4 63743 |
