Browse Forums Building A New House 1 Nov 17, 2022 9:37 am Below is a picture of my block of land (zero lot) located in Sydney. There is a 0.9m easement on the right-hand side. This easement is for maintenance and access for the next door neighbour. Would I be able to put concrete along the right-side of the house in order to create a walkway through to the backyard? Since the easement is purely for access, and the concrete won't be obstructing the neighbour's access, what are my chances of this being allowed? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17212 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16181 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3409 |
