Browse Forums Building A New House 1 Nov 08, 2022 9:24 pm Hello, See some photos attached showing the Hebel installation in progress. A few first-floor frame areas are not wrapped including the outdoor timber post, top frame, etc, Is that normal. ? I am concerned before Hebel, those to be fully wrapped. Also, see that the steel bars are installed on the bottom plate. Is that enough support? Some gaps are in the steel plate and frame only hanging from the nails. Bit confused about what to do. Any advise? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: House wrap and Hebel installation 2Nov 09, 2022 9:02 am Seriously, has your building inspector not queried that with your builder? Looks like they have used some top hat section from the scrap bin. OT, If the fixing TH section isn't square, level, secure, screws properly fixed etc The cladding is going to crack If your lucky he'll come around during the maintenance period and patch it, after that he'll stop coming. Then its your bad luck. once you've made the stage progress payment you've accepted it Back to the first line what else is defective/not fit for purpose? Goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: House wrap and Hebel installation 4Nov 09, 2022 2:18 pm Tell your builder to sign up for cladding remediation classes, BTW no need to help wa engineers to upskill we know how to fix cladding (humour) here Engineers Australia and Office of NSW Building Commissioner join forces to fix cladding Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: House wrap and Hebel installation 6Nov 14, 2022 9:09 am I am building with a well known project builder (M), we had worse than this. nearly half the house panels pulled off, frame straightened, new top hats. new panels, Articulation joints had top hats running through etc. If you are building Hebel with a vol builder its real easy to cover up poor work like this Re: House wrap and Hebel installation 7Nov 14, 2022 9:39 am I notice the new home sales spin doctors have started promoting net zero carbon homes. As if battlers and punters are going to switch to saving the planet, Lol, and nobody cares that my house -> greatest investment is falling apart. OT, I guess you are not paying enough for Sh!t Boxes, so they need to add another layer of costs.... go figure (humour) Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Vapour permeable wraps are recommended for any climate and main think it is allow walls to breath (i.e. remove water vapour) while at the same time, providing protection… 4 9805 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11360 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17207 |
