Browse Forums Building A New House Re: How wide is your hallway? 2Oct 04, 2022 10:48 am Ours is like 1m, which was fine with the original front door which was standard with a window. We ended up with a free upgrade to a wide door which kinda makes me wish our hallway was the same width as the door looking at it now. Re: How wide is your hallway? 3Oct 04, 2022 3:53 pm MrSober Ours is like 1m, which was fine with the original front door which was standard with a window. We ended up with a free upgrade to a wide door which kinda makes me wish our hallway was the same width as the door looking at it now. How wide is your door? Also, when you say 1m, is that including or excluding the skirting boards? Re: How wide is your hallway? 5Oct 05, 2022 8:43 am home2023 MrSober Ours is like 1m, which was fine with the original front door which was standard with a window. We ended up with a free upgrade to a wide door which kinda makes me wish our hallway was the same width as the door looking at it now. How wide is your door? Also, when you say 1m, is that including or excluding the skirting boards? Door is 1200mm wide, 1m that is excluding skirting. Re: How wide is your hallway? 6Oct 05, 2022 7:19 pm MrSober home2023 MrSober Ours is like 1m, which was fine with the original front door which was standard with a window. We ended up with a free upgrade to a wide door which kinda makes me wish our hallway was the same width as the door looking at it now. How wide is your door? Also, when you say 1m, is that including or excluding the skirting boards? Door is 1200mm wide, 1m that is excluding skirting. Was it ok to get the fridge through the hallway? Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 51871 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61478 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8679 |
