Browse Forums Building A New House 1 Oct 02, 2022 8:23 am I am looking at a corner block , frontage of 13.5 m. I want to go with a custom build but trying to find exactly what’s the setback from the road boundary to determine what max width house I can build. Can any advise if there is a way to lookup exact setback for a block. This is in Moreton bay regional council. Also there is retaining wall on boundary, does it affect the setback from the side as well. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Check building setback for block in North Brisbane 2Oct 02, 2022 12:11 pm https://consult.moretonbay.qld.gov.au/k ... 0106863373 But also check if you're in one of the special zones, cause they may have different ones: https://www.moretonbay.qld.gov.au/Servi ... ling-House Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8498 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3702 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15784 |
